Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Disassembling VTech MobiGo Touch Learning System Keyboard
Ce dont vous avez besoin
  1. Disassembling VTech MobiGo Touch Learning System Keyboard, Case: étape 1, image 1 de 1
    • Remove the battery covers and the four batteries.
  2. Disassembling VTech MobiGo Touch Learning System Keyboard: étape 2, image 1 de 2 Disassembling VTech MobiGo Touch Learning System Keyboard: étape 2, image 2 de 2
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. Disassembling VTech MobiGo Touch Learning System Keyboard: étape 3, image 1 de 2 Disassembling VTech MobiGo Touch Learning System Keyboard: étape 3, image 2 de 2
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: étape 4, image 1 de 2 Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: étape 4, image 2 de 2
    • Remove the six 6.5 mm Philips J0 screws that are connected to the circuit board.
    • Use light pressure to prevent damage to the circuit board.
  5. Disassembling VTech MobiGo Touch Learning System Keyboard: étape 5, image 1 de 1
    • Remove the 9.0 mm Philips J0 screw from the blue plastic cover.
    • Once the screw is removed, remove the blue plastic cover.
  6. Disassembling VTech MobiGo Touch Learning System Keyboard: étape 6, image 1 de 2 Disassembling VTech MobiGo Touch Learning System Keyboard: étape 6, image 2 de 2
    • Remove the two 4.0 mm Philips J0 screws located on the orange case.
    • Use gentle force to prevent stripping of screws.
  7. Disassembling VTech MobiGo Touch Learning System Keyboard: étape 7, image 1 de 3 Disassembling VTech MobiGo Touch Learning System Keyboard: étape 7, image 2 de 3 Disassembling VTech MobiGo Touch Learning System Keyboard: étape 7, image 3 de 3
    • Remove the two "L" shaped brackets located on both sides of the device.
    • Use the magnetic mat to store these brackets.
  8. Disassembling VTech MobiGo Touch Learning System Keyboard: étape 8, image 1 de 1
    • Locate the spring that was connected to the "L" shaped bracket and slowly remove it.
  9. Disassembling VTech MobiGo Touch Learning System Keyboard: étape 9, image 1 de 2 Disassembling VTech MobiGo Touch Learning System Keyboard: étape 9, image 2 de 2
    • Gently lift the circuit board from the case using a plastic opening tool.
    • Make sure to use a plastic opening tool for this step.
  10. Disassembling VTech MobiGo Touch Learning System Keyboard: étape 10, image 1 de 1
    • Remove the 3.5 mm Philips J0 screw located underneath the circuit board.
    • Keep the circuit board out of the way to avoid damaging it.
  11. Disassembling VTech MobiGo Touch Learning System Keyboard: étape 11, image 1 de 1
    • Slowly remove the keyboard panel.
    • Use a spudger if necessary.
    • The keys will fall out once the keyboard panel is removed.
    • Remove all of the keys and set them aside with the keyboard panel.
  12. Disassembling VTech MobiGo Touch Learning System Keyboard: étape 12, image 1 de 1
    • Gently remove the keyboard circuit board with a plastic opening tool.
RBansil
Membre depuis le 08/27/15
221 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 8-3, Eyestone Fall 2015 Membre de l'équipe USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 membres
17 tutoriels rédigés
1 commentaire de tutoriel
Was gifted a mobigo2 for my niece but it came without keyboard .. I was curious if you knew where I might find a replacement keyboard?
ROXXY - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 52
Total : 2,305
