Introduction
Required tools:
- Case opening tool, plastic
- T5 Torx driver
Estimated Time: about 5 - 10 minutes
Ce dont vous avez besoin
Outil utilisé dans cette étape :Plastic Cards$2.99
The case can be opened easily with a plastic case opening tool. Strong finger nails and an old credit card / plastic card may work too.
Lift the board gently - there is only one small connector connecting the board to the hard disk case (around the yellow market space).
On the second image, you can see the board turned over.
Further disassembly would damage the disk. I hoped to find a SATA connector within, but maybe someone knows an alternative board with the same connector.
The label on the WD Elements SE case and the labels on the harddisk can be seen here. I censored serial numbers, the WWID and the barcodes.
