Aller au contenu principal
Disassembling ZTE Racer II Phone
Ce dont vous avez besoin
  1. Disassembling ZTE Racer II Phone, Phone: étape 1, image 1 de 1
    • Carefully prise the back cover off the phone.
  2. Disassembling ZTE Racer II Phone: étape 2, image 1 de 1
    • Remove Battery, SIM Card, and MicroSD
    • Remove the four screws located around the edge of the case. They should be very small phillips heads.
  3. Disassembling ZTE Racer II Phone: étape 3, image 1 de 1
    • Using a flathead screwdriver, carefully prise the black plastic away. It's held in with a series of clips, and should come away easily.
  4. Disassembling ZTE Racer II Phone: étape 4, image 1 de 1
    • Carefully remove the ribbon cable that connects the capacitive screen to the main board. You need to carefully lift the small tab, then pull the cable out.
  5. Disassembling ZTE Racer II Phone: étape 5, image 1 de 2 Disassembling ZTE Racer II Phone: étape 5, image 2 de 2
    • Now using the flathead screwdriver, prise the plastic that makes up the front, away from the circuit board. Like the back piece, it has a series of clips around the edge, and should lift free without much effort.
  6. Disassembling ZTE Racer II Phone: étape 6, image 1 de 2 Disassembling ZTE Racer II Phone: étape 6, image 2 de 2
    • There you have it. Amazingly simple to take apart this phone.
Jacob
Membre depuis le 04/27/13
121 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 1,836
