Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
This guide will show you the quickest way to remove the front of the device so you can get to deeper parts of the device.
Pièces
Aucune pièce spécifiée.
  1. Using a Phillips screwdriver, remove the eight 9.5 mm screws on the left and right sides of the device. Using a Phillips screwdriver, remove the eight 9.5 mm screws on the left and right sides of the device.
    • Using a Phillips screwdriver, remove the eight 9.5 mm screws on the left and right sides of the device.
  2. Remove these seven 11.5 mm screws and place aside.
    • Remove these seven 11.5 mm screws and place aside.
  3. Lift the right side off of the device and place aside.
    • Lift the right side off of the device and place aside.
    • Repeat for left side.
  4. Lift the top gently but firmly from the back of the device. Allow it to rest on the back without reattaching it.
    • Lift the top gently but firmly from the back of the device. Allow it to rest on the back without reattaching it.
    • Do not pull the top too far as there are wires attached to it.
  5. Gently lift up on the indicated tabs to disengage them from the hooks holding them in place. Gently lift up on the indicated tabs to disengage them from the hooks holding them in place.
    • Gently lift up on the indicated tabs to disengage them from the hooks holding them in place.
  6. Fix Kits pour écrans LCD d'iPhone
    L'option économique couverte par notre garantie à vie.
    Acheter des kits
    Réduisez les coûts de réparation et non pas la qualité.
    Acheter des kits
  7. Lift up the top while firmly sliding it towards the back of the device.
    • Lift up the top while firmly sliding it towards the back of the device.
    • Do not lift the top up too high as there are cords that need to be detached before the top can be removed.
    • The next step is a zoom-in of the indicated area.
  8. Using forceps or fingers, remove the small black wire indicated.
    • Using forceps or fingers, remove the small black wire indicated.
    • Grip the wire near its base and pull gently but firmly until it pops out of the slot.
  9. This step deals with the indicated area of the device. Using fingers or tweezers, lift the indicated tabs out until the cord's restraint looks like the final picture. Gently pull on the cord near its base until it comes free of the restraint.
    • This step deals with the indicated area of the device.
    • Using fingers or tweezers, lift the indicated tabs out until the cord's restraint looks like the final picture.
    • Gently pull on the cord near its base until it comes free of the restraint.
  10. This step deals with the indicated area of the device. Lift the indicated tabs out until the restraint looks like the final picture. Gently pull on the cord until it comes free of the attachment.
    • Lift the indicated tabs out until the restraint looks like the final picture.
    • Gently pull on the cord until it comes free of the attachment.
    • The top section of the device should now be free of the body. Place it aside in a safe place.
  11. This step deals with the indicated portion of the the device. Lift the indicated tabs out until they look like the final picture. Gently pull on the cord until it comes free of its restraint.
    • This step deals with the indicated portion of the the device.
    • Lift the indicated tabs out until they look like the final picture.
    • Gently pull on the cord until it comes free of its restraint.
  12. This step deals with the indicated area of the device. Neither of the indicated cords have restraints on them like the previous ones. Use tweezers or fingers to pull firmly on the base of each cord until it comes free. Neither of the indicated cords have restraints on them like the previous ones. Use tweezers or fingers to pull firmly on the base of each cord until it comes free.
    • Neither of the indicated cords have restraints on them like the previous ones. Use tweezers or fingers to pull firmly on the base of each cord until it comes free.
  13. This step deals with the indicated area of the device. Use tweezers or fingers and firmly pull straight out on the cord until it comes free.
    • Use tweezers or fingers and firmly pull straight out on the cord until it comes free.
  14. This step deals with the indicated area of the device. Using tweezers or fingers, lift gently on the tab indicated to free the front from the body of the device. Rotate device 180 degrees and repeat for other side.
    • Using tweezers or fingers, lift gently on the tab indicated to free the front from the body of the device.
    • Rotate device 180 degrees and repeat for other side.
    • Rotate the front slightly forward to keep the tabs from re-engaging on their hooks.
  15. Wiggle the front gently while pulling it forward until it comes free of the body of the device.
    • Wiggle the front gently while pulling it forward until it comes free of the body of the device.
2 autre(s) ont terminé cette réparation.
NathanB
Membre depuis le 13/04/2011
263 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 4-1, Regan Spring 2011 Membre de l'équipe Cal Poly, Team 4-1, Regan Spring 2011
CPSU-REGAN-S11S4G1
3 membres
5 tutoriels rédigés
Excellent and clear instructions, thankyou. Only trouble is the CD Changer device door is not opening! As I have not actually carried out the Front Panel removal at present I am hoping my problem will expose itself when I complete your instructions in practicality. Thanks again. Denis.
Denis Parker - Réponse
Thanks a lot for the guide! I was able to fix my problem of cassettes playing too slow. You rock!
Jirka Arbter - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 17
Total : 3,622
