Aller au contenu principal
Disassembling iPhone 4S Back Camera
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Disassembling iPhone 4S Back Camera, Disassembling iPhone 4S Battery: étape 1, image 1 de 1
    • Using a 5-point pentalobe screwdriver, unscrew the 2 pentalobe on the bottom of the phone near the dock connector.
  2. Disassembling iPhone 4S Back Camera: étape 2, image 1 de 1
    • Push the back glass towards the top of the phone.
  3. Disassembling iPhone 4S Back Camera: étape 3, image 1 de 1
    • Using a #000 Phillips screwdriver, unscrew the 2 very small Phillips screws.
  4. Disassembling iPhone 4S Back Camera: étape 4, image 1 de 2 Disassembling iPhone 4S Back Camera: étape 4, image 2 de 2
    • Using a plastic opener tool, pry up the battery connector shield. Be careful not to lose the smaller antenna connector shield under the top connector sheild.
    • Using a plastic opener tool, pry up the battery connector.
  5. Disassembling iPhone 4S Back Camera: étape 5, image 1 de 1
    • Pull upwards on the plastic tab. If it's the first time, you may have to use the plastic pry tool on the outside (right) edge of the battery to loosen battery first.
    • Then, out pops the battery.
  6. Disassembling iPhone 4S Back Camera, Disassembling iPhone 4S Back Camera: étape 6, image 1 de 1
    • Unscrew the 4 phillips screws holding the shield covering 6 of the 8 connectors.
    • Make sure to keep track of which screws are which, they very by tenths of a millimeter.
  7. Disassembling iPhone 4S Back Camera: étape 7, image 1 de 2 Disassembling iPhone 4S Back Camera: étape 7, image 2 de 2
    • Using a plastic opening tool, pry the back camera connector from the logic board.
    • Be careful not to lose the small square peice of plastic covering the bottom of the camera, it comes off very easily.
4 autres ont terminé cette réparation.
Chandler Skinner
Membre depuis le 10/15/11
3 710 Réputation
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 2,676
