Aller au contenu principal
Disassembling iRobot Roomba 551 Bottom Plate
Ce dont vous avez besoin
  1. Disassembling iRobot Roomba 551 Bottom Plate, Side Brush: étape 1, image 1 de 1
    • Place your Roomba upside-down on a hard surface.
  2. Disassembling iRobot Roomba 551 Bottom Plate: étape 2, image 1 de 1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. Disassembling iRobot Roomba 551 Bottom Plate: étape 3, image 1 de 1
    • Gently pull upwards on the brush to remove it.
  4. Disassembling iRobot Roomba 551 Bottom Plate, Bottom Plate: étape 4, image 1 de 1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. Disassembling iRobot Roomba 551 Bottom Plate: étape 5, image 1 de 2 Disassembling iRobot Roomba 551 Bottom Plate: étape 5, image 2 de 2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. Disassembling iRobot Roomba 551 Bottom Plate: étape 6, image 1 de 1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
Deborah Newberry
Membre depuis le 01/23/14
623 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 13-14, Regan Winter 2014 Membre de l'équipe Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 membres
19 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 34
Total : 2,361
