Aller au contenu principal
Disassembling the Linksys E1200
Ce dont vous avez besoin
  1. Disassembling the Linksys E1200, Cover and Circuit Board: étape 1, image 1 de 3 Disassembling the Linksys E1200, Cover and Circuit Board: étape 1, image 2 de 3 Disassembling the Linksys E1200, Cover and Circuit Board: étape 1, image 3 de 3
    • Opening the device will void your warranty.
    • Anti-slip pads cover three screws that hold the device together. Pry off the pads to access the screws.
    • Remove the three screws.
    • Save the pads for reassembly.
  2. Disassembling the Linksys E1200: étape 2, image 1 de 3 Disassembling the Linksys E1200: étape 2, image 2 de 3 Disassembling the Linksys E1200: étape 2, image 3 de 3
    • Once the three screws are removed, the device is ready for disassembly.
    • Push up on the rear flap while holding down on the rest of the body. This will open a small gap.
    • Insert the plastic opening tool in the gap and begin prying on the corner.
    • Continue to pry around the body of the case. Separate both sides of the case with this method.
  3. Disassembling the Linksys E1200: étape 3, image 1 de 2 Disassembling the Linksys E1200: étape 3, image 2 de 2
    • Once the sides are released, the front of the cover can be removed.
    • Use a plastic opening tool to separate the front of the cover from the body.
    • It is helpful to use a different plastic opening tool as a wedge on the sides to prevent them from snapping back together.
  4. Disassembling the Linksys E1200: étape 4, image 1 de 3 Disassembling the Linksys E1200: étape 4, image 2 de 3 Disassembling the Linksys E1200: étape 4, image 3 de 3
    • The cover can now be removed.
    • To repair anything on the circuit board, use the plastic opening tool to pull back on the two tabs holding it down.
    • Use caution when pulling on the tabs as they are stiff and easy to break.
    • Keep the tabs if they snap off. The tabs can be reattached with glue when reassembling the device.
  5. Disassembling the Linksys E1200: étape 5, image 1 de 3 Disassembling the Linksys E1200: étape 5, image 2 de 3 Disassembling the Linksys E1200: étape 5, image 3 de 3
    • If the antenna needs to be disconnected, desolder the connection and reattach it prior to reassembly.
    • If the ethernet ports, power port, or reset button are damaged, the large solder points allow you to replace them.
    • Many components on the board cannot be serviced. These components were attached by a machine and cannot be removed.
13 autres ont terminé cette réparation.
Tahisha Hicks
Membre depuis le 02/24/14
409 Réputation
4 tutoriels rédigés
Équipe
Michigan Tech, Team 5-4, Lauer Spring 2014 Membre de l'équipe Michigan Tech, Team 5-4, Lauer Spring 2014
MTU-LAUER-S14S5G4
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 7,025
