Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Disassembling the Thomas Ride On Train
Ce dont vous avez besoin
    1. Disassembling the Thomas Ride On Train, Preparation: étape 1, image 1 de 1
      • You will need quite a lot of space to work on the engine as it effectively has to be stripped right down to get to the key components
      • Before commencing, remove the battery from the system. This will make the train lighter and avoid any electrical issues. See Replacing the battery guide.
      Demander à FixBot
      Ajouter un commentaire
    2. Disassembling the Thomas Ride On Train, Removing the wheel cover: étape 2, image 1 de 2 Disassembling the Thomas Ride On Train, Removing the wheel cover: étape 2, image 2 de 2
      • Turn the train upside down
      • Remove the screws down the centre and across the front to release the wheel cover
      • You may need to lever the cover out at the front with something like a putty knife
      • Remove the loudspeaker by unscrewing the 3 screws that attach it to this cover.
      Demander à FixBot
    3. Disassembling the Thomas Ride On Train, Removing the front wheels: étape 3, image 1 de 1
      • The front two pairs of wheels are screwed on with self tapping screws. Remove the four screws that hold on each of the wheels and keep safe
      • Reassembly
      • When screwing the wheels back on note that there are counterbores in the plastic clips that fit onto the raised parts on the case
      Demander à FixBot
    4. Disassembling the Thomas Ride On Train, Removing the engine: étape 4, image 1 de 1
      • The electric motor is held in place by two different things.
      • Firstly two screws and a yellow plastic bracket.
      • Also on the right is a clip that hold the motor and gearbox in place. You can release this by inserting a pallet knife or a screwdriver between the motor and case
      • Note that you won't be able to completely remove the engine at this point as it is still connected by wires
      Demander à FixBot
    5. Disassembling the Thomas Ride On Train, Removing the side panels: étape 5, image 1 de 1
      • Over the wheel arches are 2 more plastic panels, they are held in place by screws. Note that the outer screws are a smaller size.
      Demander à FixBot
    6. Disassembling the Thomas Ride On Train, Removing the body: étape 6, image 1 de 2 Disassembling the Thomas Ride On Train, Removing the body: étape 6, image 2 de 2
      • The next 5 screws hold the body to the chassis. The top also is clipped in place at the back
      • You can access most of the components at this point including disconnecting the motor and the power switch
      • Reassembly
      • Take care not to trap wires, you should be able to route the cables around the case
      Demander à FixBot
    7. Disassembling the Thomas Ride On Train, Power Switch: étape 7, image 1 de 1
      • The power is connected via spade connectors.
      • Make a note of their position before removing.
      • By removing the three screws you can access the switch which is an off the shelf double pole double throw switch but only one throw is used.
      • This had broken in my train but I simply reversed it to use the other throw which did work correctly. This might be an option if you can't find a replacement part.
      Demander à FixBot
    8. Disassembling the Thomas Ride On Train, Removing the chimney: étape 8, image 1 de 1
      • To access the controls you need to remove the chimney, this step may require a shorter or stubby screwdriver
      • Once the screws are removed the chimney slides up with respect to the body
      • Reassembly
      • Take care to ensure that all of the wires pass through the large hole and are not trapped
      Demander à FixBot
    9. Disassembling the Thomas Ride On Train, Removing the handlebars: étape 9, image 1 de 1
      • A single screw inside the chimney holds this in place, again you may need a short screwdriver to access this
      Demander à FixBot
    10. Disassembling the Thomas Ride On Train, Removing the console: étape 10, image 1 de 3 Disassembling the Thomas Ride On Train, Removing the console: étape 10, image 2 de 3 Disassembling the Thomas Ride On Train, Removing the console: étape 10, image 3 de 3
      • The console is held in place by the 4 inner screws, note you don't need to remove the outer screws or screws in the handlebars
      • Note how the block attached to the lever is positioned against the switch. In my train this was 180degrees reversed and hence the lever did not do anything.
      • The three buttons need to be correctly orientated, they have little bars to fit into slots
      • Note the newer model may look slightly different to this
      Demander à FixBot
Andy from Workshopshed
Membre depuis le 05/21/13
447 Réputation
3 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 21
30 derniers jours : 73
Total : 5,987
