Aller au contenu principal
Disassembly of Sony BDP-BX18 Blu-ray player
Ce dont vous avez besoin
  1. Disassembly of Sony BDP-BX18 Blu-ray player, Blu-ray player: étape 1, image 1 de 1
    • Remove the face plate by depressing the small plastic tab
    • *NOTE: eject disk tray first before dis-assembly to gain access.
  2. Disassembly of Sony BDP-BX18 Blu-ray player: étape 2, image 1 de 1
    • Release front 4 tabs in order to slide main cover forward.
    • *NOTE: slide only a few mils forwards before next step.
  3. Disassembly of Sony BDP-BX18 Blu-ray player: étape 3, image 1 de 1
    • Release tabs on both left and right sides of unit while maintaining forward pressure to slide cover off.
    • *NOTE: The arrows depict where the tabs are located.
  4. Disassembly of Sony BDP-BX18 Blu-ray player: étape 4, image 1 de 1
    • After cover removal, you should now have access to the internal components.
    • We will begin removing the power supply. Compress the center clip and open plastic shield.
  5. Disassembly of Sony BDP-BX18 Blu-ray player: étape 5, image 1 de 1
    • Release clip to remove 6 pin power cable.
  6. Disassembly of Sony BDP-BX18 Blu-ray player: étape 6, image 1 de 1
    • Unscrew two mounting screw for power supply. Slide forward and pull out for removal.
  7. Disassembly of Sony BDP-BX18 Blu-ray player: étape 7, image 1 de 1
    • This should be your current progress thus far.
  8. Disassembly of Sony BDP-BX18 Blu-ray player: étape 8, image 1 de 1
    • Release tab to remove plastic power supply shield.
  9. Disassembly of Sony BDP-BX18 Blu-ray player: étape 9, image 1 de 2 Disassembly of Sony BDP-BX18 Blu-ray player: étape 9, image 2 de 2
    • Remove the three screws.
    • Now depress metal tab to fully remove heat sink clamp.
  10. Disassembly of Sony BDP-BX18 Blu-ray player: étape 10, image 1 de 2 Disassembly of Sony BDP-BX18 Blu-ray player: étape 10, image 2 de 2
    • Pull on indicated ribbon cable to begin removal of front display.
    • Now remove single screw to remove front display panel.
  11. Disassembly of Sony BDP-BX18 Blu-ray player: étape 11, image 1 de 1
    • This should be you current dis-assembly progress thus far.
  12. Disassembly of Sony BDP-BX18 Blu-ray player: étape 12, image 1 de 2 Disassembly of Sony BDP-BX18 Blu-ray player: étape 12, image 2 de 2
    • Next, remove all three ribbon cables attached to optical disc drive.
    • *NOTE: largest ribbon cable has small secure clamp, be sure to release it before pulling.
    • Now unscrew both mounting screw for optical disc drive for complete removal.
  13. Disassembly of Sony BDP-BX18 Blu-ray player: étape 13, image 1 de 1
    • To completely remove the main board, locate screws on back of unit. Unscrew these 2 screws and then slide main board out.
  14. Disassembly of Sony BDP-BX18 Blu-ray player: étape 14, image 1 de 1
    • You should now be completely dis-assembled. For further dis-assembly of the optical disc drive, continue to step 15.
  15. Disassembly of Sony BDP-BX18 Blu-ray player: étape 15, image 1 de 3 Disassembly of Sony BDP-BX18 Blu-ray player: étape 15, image 2 de 3 Disassembly of Sony BDP-BX18 Blu-ray player: étape 15, image 3 de 3
    • First remove metal shroud exposing tabs.
    • Peel back security tape and release all 4 tabs (2 on each side) for removal of top cover.
    • Now the internal components of the optical disc drive are now exposed.
6 autres ont terminé cette réparation.
TEAM 7
Membre depuis le 04/01/13
335 Réputation
1 tutoriel rédigé
7 commentaires
Hi! I have just a quick question! The front display panel of my Sony Blu Ray player had broken! The small board with the USB mounted onto it, remote sensor and buttons! What is the name of this board? I was looking to order a replacement
earlovann - Réponse
Nice info. Need to know how to get replacement bluray player. Any ideas? Do not want to buy new TV yet.
Keith - Réponse
now I know I'm missing lots of parts...lol
Tina Marie - Réponse
Thanks! the hardest part was getting the tray out.
Blake Horsfall - Réponse
Cannon proceed past 3, I dont understand how you are supposed to release the tabs and press forward, I only have two hands. The tabs click back in place immediately and I don't have any place to get a grip of to remove the plate
Sira Q - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 49
Total : 17,024
