Introduction
In this guide, we will be showing you how to remove and replace the Display Assembly.
Ce dont vous avez besoin
Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
Disconnect the antenna cable.
Close the display.
Turn the computer upside down with the back of the computer facing you.
From the bottom of the computer, remove the two M2.5 x 8-mm screws labeled "D."
From the back of the computer, remove the two M2.5 x 8-mm screws labeled "D."
Turn the computer right-side up and open the display.
Carefully remove the antenna cable and the display cables from their routing guides.
