Aller au contenu principal
Dodge Ram 1500 Headlight Bulb Replacement
Ce dont vous avez besoin
  1. Dodge Ram 1500 Headlight Bulb Replacement, Headlight Assembly: étape 1, image 1 de 3 Dodge Ram 1500 Headlight Bulb Replacement, Headlight Assembly: étape 1, image 2 de 3 Dodge Ram 1500 Headlight Bulb Replacement, Headlight Assembly: étape 1, image 3 de 3
    • Open the hood by pulling the hood lever in the driver-side footwell.
    • Reach under the center of the grille and press the hood latch.
  2. Dodge Ram 1500 Headlight Bulb Replacement: étape 2, image 1 de 1
    • In this guide we will be removing the left headlight. The steps are mirrored for the right headlight.
  3. Dodge Ram 1500 Headlight Bulb Replacement: étape 3, image 1 de 3 Dodge Ram 1500 Headlight Bulb Replacement: étape 3, image 2 de 3 Dodge Ram 1500 Headlight Bulb Replacement: étape 3, image 3 de 3
    • Use the 10 mm socket wrench to unscrew the first of three 12 mm long 10 mm hex-head screws holding in the headlight assembly. The screw is located just to the left of the headlight assembly.
    • Unscrew the second screw located approximately 6 inches below the first.
    • Locate the third screw at the bottom left corner of the headlight assembly just behind the bumper and remove.
    • When re-installing the screws do not over tighten. Over tightening the screws will result in stripped threads.
  4. Dodge Ram 1500 Headlight Bulb Replacement: étape 4, image 1 de 2 Dodge Ram 1500 Headlight Bulb Replacement: étape 4, image 2 de 2
    • Approach this step with the process of unbuttoning a shirt in mind.
    • Be careful if the rubber gasket is dry-rotted. Use vaseline to re-moisturize if necessary. Manipulating dry-rotted rubber will result in tearing.
    • Pinch the bottom of the rubber gasket at the left side of the assembly and remove it from the plastic "buttons" on the headlight assembly.
  5. Dodge Ram 1500 Headlight Bulb Replacement: étape 5, image 1 de 2 Dodge Ram 1500 Headlight Bulb Replacement: étape 5, image 2 de 2
    • Locate the blue headlight wire. Use a flathead screwdriver to pry up one side of the clamping teeth and pull the connector off.
    • Locate the green turn signal wire clamp. Use a flathead screwdriver to push in the tab on the side and pull off the connector.
    • Now that all connections between the car and the headlight assembly are disconnected, it is safe to remove the headlight assembly from the truck.
  6. Dodge Ram 1500 Headlight Bulb Replacement, Headlight Bulb: étape 6, image 1 de 2 Dodge Ram 1500 Headlight Bulb Replacement, Headlight Bulb: étape 6, image 2 de 2
    • Rotate the outer ring of the headlight bulb holder counterclockwise to remove it.
    • Carefully pull the headlight bulb holder out of its socket.
    • When installing a headlight bulb, do not touch the bulb with your bare skin. Wear gloves when installing a new headlight bulb. Halogen bulbs are sensitive to skin oils, and the bulb may burn out quickly if you touch the bulb during installation.
    • If you accidentally touch the bulb, clean it immediately using rubbing alcohol on a clean cloth.
Michael Saggese
Membre depuis le 10/05/12
1 021 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 3-24, Amido Fall 2012 Membre de l'équipe Cal Poly, Team 3-24, Amido Fall 2012
CPSU-AMIDO-F12S3G24
4 membres
11 tutoriels rédigés
Un commentaire
What is that rubber gasket called or a part # please, mine is all torn from previous owner
diggemsmacks2000 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 70
30 derniers jours : 299
Total : 25,053
