Aller au contenu principal
Door Hinge Replacement
Ce dont vous avez besoin
  1. Door Hinge Replacement, Hinge: étape 1, image 1 de 2 Door Hinge Replacement, Hinge: étape 1, image 2 de 2
    • Take measurements of the door hinge using a tape measure and use the measurements to find a replacement door hinge.
  2. Door Hinge Replacement: étape 2, image 1 de 2 Door Hinge Replacement: étape 2, image 2 de 2
    • Use two sturdy pieces of wood or cardboard that can keep the door in place and put them underneath the door.
    • Make sure that the door isn’t slanted or tilted to make it easier to replace the new door hinge.
  3. Door Hinge Replacement: étape 3, image 1 de 2 Door Hinge Replacement: étape 3, image 2 de 2
    • Remove the three screws from the hinge that are connected to the door by using a Phillips 1 screwdriver.
    • Remove the three screws from the hinge that are connected to the door frame using a Phillips #1 screwdriver.
  4. Door Hinge Replacement: étape 4, image 1 de 2 Door Hinge Replacement: étape 4, image 2 de 2
    • Repeat Step 3 with the bottom hinge on the door.
  5. Door Hinge Replacement: étape 5, image 1 de 2 Door Hinge Replacement: étape 5, image 2 de 2
    • Rub sandpaper on the areas where the new hinges will be.
    • This makes sure that splinters or any wood debris from both the frame and the door will be removed.
  6. Door Hinge Replacement: étape 6, image 1 de 2 Door Hinge Replacement: étape 6, image 2 de 2
    • When replacing your new door hinge, make sure that the hinge that is facing towards you can be fully closed
  7. Door Hinge Replacement: étape 7, image 1 de 3 Door Hinge Replacement: étape 7, image 2 de 3 Door Hinge Replacement: étape 7, image 3 de 3
    • Align the new door hinge with the screw holes in the frame and screw in the new door hinge in the frame.
    • Repeat this with the bottom area of the door.
  8. Door Hinge Replacement: étape 8, image 1 de 3 Door Hinge Replacement: étape 8, image 2 de 3 Door Hinge Replacement: étape 8, image 3 de 3
    • Align the new door hinge with the screw holes in the door and screw in the new door hinge.
  9. Door Hinge Replacement: étape 9, image 1 de 2 Door Hinge Replacement: étape 9, image 2 de 2
    • Spray a small amount of WD-40 at the back top and bottom hinge and wipe it down with an old rag.
Ligne d'arrivée
Zeniff Aviles
Membre depuis le 01/19/21
234 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G31, Woodhouse Winter 2021 Membre de l'équipe York University, Team S1-G31, Woodhouse Winter 2021
YORK-WOODHOUSE-W21S1G31
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 14
Total : 806
