Aller au contenu principal
Door Stop Replacement
Ce dont vous avez besoin
  1. Door Stop Replacement, Door Stop: étape 1, image 1 de 3 Door Stop Replacement, Door Stop: étape 1, image 2 de 3 Door Stop Replacement, Door Stop: étape 1, image 3 de 3
    • Twist the anchor fitting of the old door stop in counter clockwise direction.
    • Remove the anchor fitting from the mount.
    • Anchor fitting: is a part of the door stop circled in red.
  2. Door Stop Replacement: étape 2, image 1 de 3 Door Stop Replacement: étape 2, image 2 de 3 Door Stop Replacement: étape 2, image 3 de 3
    • Use a drill (or a screwdriver) to remove the two screws from the mount base.
    • After you remove the mount base, use the hammer to reposition these two screws.
  3. Door Stop Replacement: étape 3, image 1 de 2 Door Stop Replacement: étape 3, image 2 de 2
    • Use a screwdriver to remove the mount base out of the new anchor fitting by spinning the screwdriver counter-clockwise.
  4. Door Stop Replacement: étape 4, image 1 de 3 Door Stop Replacement: étape 4, image 2 de 3 Door Stop Replacement: étape 4, image 3 de 3
    • Using a screwdriver or a drill, attach the new mount base to the wall with the two screws.
  5. Door Stop Replacement: étape 5, image 1 de 3 Door Stop Replacement: étape 5, image 2 de 3 Door Stop Replacement: étape 5, image 3 de 3
    • Attach the anchor fitting into the mount base by rotating it clockwise.
  6. Door Stop Replacement: étape 6, image 1 de 2 Door Stop Replacement: étape 6, image 2 de 2
    • Remove the old door fitting by rotating it counter-clockwise.
  7. Door Stop Replacement: étape 7, image 1 de 3 Door Stop Replacement: étape 7, image 2 de 3 Door Stop Replacement: étape 7, image 3 de 3
    • Use the drill to remove the two screws out of the threaded insert.
    • Clean the screws holes (if necessary) before putting a new screw in.
  8. Door Stop Replacement: étape 8, image 1 de 3 Door Stop Replacement: étape 8, image 2 de 3 Door Stop Replacement: étape 8, image 3 de 3
    • Insert a screwdriver into the bottom hole of the threaded insert and rotate it counter-clockwise to remove the threaded insert.
  9. Door Stop Replacement: étape 9, image 1 de 2 Door Stop Replacement: étape 9, image 2 de 2
    • Place the threaded insert onto the door.
    • Using a screwdriver or a drill, attach the threaded insert to the door with two screws.
  10. Door Stop Replacement: étape 10, image 1 de 3 Door Stop Replacement: étape 10, image 2 de 3 Door Stop Replacement: étape 10, image 3 de 3
    • Assemble the rest of the door stop in the following order:
    • Spring.
    • Rectangular compartment.
    • Door stop button.
    • Outer shell.
    • Place the door stopper onto the threaded insert and and attach it by rotating it clockwise.
Khoa Bui
Membre depuis le 09/20/20
198 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G111, Woodhouse Fall 2020 Membre de l'équipe York University, Team S1-G111, Woodhouse Fall 2020
YORK-WOODHOUSE-F20S1G111
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 15
30 derniers jours : 89
Total : 3,150
