Aller au contenu principal
Doov v15 Battery Replacement
Ce dont vous avez besoin
  1. Doov v15 Battery Replacement, Battery: étape 1, image 1 de 1
    • Use the Jimmy to crack open the phone's back cover. Slide it under an edge of the phones back cover and carefully loosen the edge. The casing should pop open slightly.
  2. Doov v15 Battery Replacement: étape 2, image 1 de 3 Doov v15 Battery Replacement: étape 2, image 2 de 3 Doov v15 Battery Replacement: étape 2, image 3 de 3
    • Use an ifixit opening tool to slide around the phones back cover, loosening it and allowing for an easy removal. It should easily separate from the chassis. Make sure to trace it around the entire phone.
  3. Doov v15 Battery Replacement: étape 3, image 1 de 1
    • Once the back casing is removed, the battery will be visible. Prepare your replacement battery (BL-C-17) and use the ifixit opening tool to remove the battery. Place the ifixit opening tool at the top of the battery and pull it back, or simply use your hand to remove it.
  4. Doov v15 Battery Replacement: étape 4, image 1 de 2 Doov v15 Battery Replacement: étape 4, image 2 de 2
    • Install the replacement battery by sliding it downward into the empty slot. Make sure the front of the battery faces you.
2 autres ont terminé cette réparation.
Elijah Taylor
Membre depuis le 09/08/23
398 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 29
Total : 146
