Aller au contenu principal
Doov v15 Camera Replacement
Ce dont vous avez besoin
  1. Doov v15 Camera Replacement, Camera: étape 1, image 1 de 1
    • Use the Jimmy to crack open the phone's back cover. Slide it under an edge of the phones back cover and carefully loosen the edge. The casing should pop open slightly.
  2. Doov v15 Camera Replacement: étape 2, image 1 de 3 Doov v15 Camera Replacement: étape 2, image 2 de 3 Doov v15 Camera Replacement: étape 2, image 3 de 3
    • Use an ifixit opening tool to slide around the phones back cover, loosening it and allowing for an easy removal. It should easily separate from the chassis. Make sure to trace it around the entire phone.
    • Disconnect the Battery: Once the back casing is removed, the battery will be visible. Use the ifixit opening tool to remove the battery. Place the ifixit opening tool at the top of the battery and pull it back, or simply use your hand to remove it.
  3. Doov v15 Camera Replacement: étape 3, image 1 de 3 Doov v15 Camera Replacement: étape 3, image 2 de 3 Doov v15 Camera Replacement: étape 3, image 3 de 3
    • Once you disconnect the battery, use the iFixit Precision Bit Driver and iFixit Precision 4 mm Screwdriver Oval Drive Bit (0.5). Start unscrewing each screw clock wise until they come out. Repeat the steps and unscrew all the screw.
    • Make sure to keep the screws together in a bag or magnetic mat to ensure they aren't lost or misplaced.
  4. Doov v15 Camera Replacement: étape 4, image 1 de 3 Doov v15 Camera Replacement: étape 4, image 2 de 3 Doov v15 Camera Replacement: étape 4, image 3 de 3
    • After all screws are removed, use the iFixit opening tool to gently pry open and seperate the chassis.
    • Be cautious to avoid damaging internal components. Slide it around the phone to loosen it and gently remove the chassis.
  5. Doov v15 Camera Replacement: étape 5, image 1 de 3 Doov v15 Camera Replacement: étape 5, image 2 de 3 Doov v15 Camera Replacement: étape 5, image 3 de 3
    • Locate and Disconnect camera. You will find the camera on top-left corner. Use jimmy to puff it and disconnect any cables or connectors.
    • Place a new camera and with the help of soldering Gun connect all the cables and any connectors back.
Elijah Taylor
Membre depuis le 09/08/23
398 Réputation
2 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 126
