Introduction
Purchasing a new or used display/digitizer will be necessary if yours is broken.
Ce dont vous avez besoin
The rear panel is secured to the front case and can simply be pried apart without damage.
Remove the four screws holding the motherboard inplace.
Using the flat end of a spudger or tweezers, remove the three cables connected to the motherboard.
The cables can be disconnected by lifting up on the black section of the socket.
Once the lever is lifted, pull out the cable by gently tugging on it.
2 autres ont terminé cette réparation.
