Introduction
This guide will walk you through how to replace the battery of the device. In order to do this you must first remove the back cover. Once the back cover is off, you can remove and replace the battery.
Ce dont vous avez besoin
Insert the plastic opening tool between the white back cover and black front over.
Outil utilisé dans cette étape :Plastic Cards$2.99
Insert the plastic card under the battery and use it to remove the battery from the device.
Presque terminé !
