Aller au contenu principal
Dragon Touch MID 7138 Motherboard Replacement
Ce dont vous avez besoin
  1. Dragon Touch MID 7138 Motherboard Replacement, Back Cover: étape 1, image 1 de 1
    • Wedge a plastic spudger between the back panel and the screen to begin lifting the back cover.
    • Wedge around all edges until the back cover pops off entirely.
  2. Dragon Touch MID 7138 Motherboard Replacement: étape 2, image 1 de 1
    • Gently pry the back cover from the screen using your hands.
  3. Dragon Touch MID 7138 Motherboard Replacement, Motherboard: étape 3, image 1 de 3 Dragon Touch MID 7138 Motherboard Replacement, Motherboard: étape 3, image 2 de 3 Dragon Touch MID 7138 Motherboard Replacement, Motherboard: étape 3, image 3 de 3
    • Remove tape covering wire joints
    • Remove (3) 2.5mm screws using a PH001 screw driver.
    • The screws locations are highlighted in the image to the left.
  4. Dragon Touch MID 7138 Motherboard Replacement: étape 4, image 1 de 1
    • Remove black tape and using your fingers, pull the orange ribbon labeled BSR028-V3-KDX out of its port.
  5. Dragon Touch MID 7138 Motherboard Replacement: étape 5, image 1 de 1
    • Similar to previous step, pull the large U2 ribbon gentle out of its port.
  6. Dragon Touch MID 7138 Motherboard Replacement: étape 6, image 1 de 1
    • Remove the last orange ribbon labeled 24 by pulling the motherboard away from the ribbon
  7. Dragon Touch MID 7138 Motherboard Replacement: étape 7, image 1 de 2 Dragon Touch MID 7138 Motherboard Replacement: étape 7, image 2 de 2
    • Desolder the wires attached to the mother board with a soldering iron.
    • Then pull the wires from the joints.
Trevor Farkas
Membre depuis le 01/26/17
101 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 2-4, Baechle Spring 2017 Membre de l'équipe IUPUI, Team 2-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G4
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 592
