Aller au contenu principal
Dragon Touch Y88X Plus Battery Replacement
Ce dont vous avez besoin
  1. Dragon Touch Y88X Plus Battery Replacement, Battery: étape 1, image 1 de 1
    • Remove the back case using a plastic opening tool or spudger.
    • Start at the corners and work your way around the perimeter of the tablet.
    • Be gentle to avoid damaging the case or any internal components.
  2. Dragon Touch Y88X Plus Battery Replacement: étape 2, image 1 de 2 Dragon Touch Y88X Plus Battery Replacement: étape 2, image 2 de 2
    • Identify the tablet's battery. It is usually a flat, rectangular component connected to the motherboard.
    • Carefully peel the old battery from the adhesive using your iFixit pry tool.
    • Be very cautious not to puncture the battery if yours has expanded . If the battery is swollen, read the article on What to do with a swollen battery for assistance.
  3. Dragon Touch Y88X Plus Battery Replacement: étape 3, image 1 de 2 Dragon Touch Y88X Plus Battery Replacement: étape 3, image 2 de 2
    • Use a soldering iron to disconnect each connector individually from the motherboard.
  4. Dragon Touch Y88X Plus Battery Replacement: étape 4, image 1 de 1
    • Remove any adhesive from the battery.
    • Remove the battery.
2 autres ont terminé cette réparation.
Bavly Aziz
Membre depuis le 10/30/23
195 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 1-4, Petersen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 1-4, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G4
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 7
Total : 103
