Aller au contenu principal
Dragon Touch Y88X Plus Motherboard Replacement
Ce dont vous avez besoin
  1. Dragon Touch Y88X Plus Motherboard Replacement, Motherboard: étape 1, image 1 de 1
    • Remove the back case using a plastic opening tool or spudger.
    • Start at the corners and work your way around the perimeter of the tablet.
    • Be gentle to avoid damaging the case or any internal components.
  2. Dragon Touch Y88X Plus Motherboard Replacement: étape 2, image 1 de 1
    • Remove any adhesive strips keeping wires in place.
  3. Dragon Touch Y88X Plus Motherboard Replacement: étape 3, image 1 de 1
    • Desolder the wires connected to the motherboard to disconnect the battery and speaker.
  4. Dragon Touch Y88X Plus Motherboard Replacement: étape 4, image 1 de 2 Dragon Touch Y88X Plus Motherboard Replacement: étape 4, image 2 de 2
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on the three ZIF connectors.
    • Be sure to pry up on the hinged flap, not the connector socket.
    • Use a spudger to slide the ribbon cables from the connectors.
  5. Dragon Touch Y88X Plus Motherboard Replacement: étape 5, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the edges of the motherboard.
  6. Dragon Touch Y88X Plus Motherboard Replacement: étape 6, image 1 de 1
    • Gently lift the motherboard from the device.
2 autres ont terminé cette réparation.
Cody Camara
Membre depuis le 11/01/23
149 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 1-4, Petersen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 1-4, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G4
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 69
