Aller au contenu principal
Draining a Toilet Tank
  1. Draining a Toilet Tank, Tank Lid: étape 1, image 1 de 3 Draining a Toilet Tank, Tank Lid: étape 1, image 2 de 3 Draining a Toilet Tank, Tank Lid: étape 1, image 3 de 3
    • Lift the tank lid up and away from the toilet tank.
  2. Draining a Toilet Tank, Shutting off the Water Supply to a Toilet: étape 2, image 1 de 2 Draining a Toilet Tank, Shutting off the Water Supply to a Toilet: étape 2, image 2 de 2
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Draining a Toilet Tank, Draining a Toilet Tank: étape 3, image 1 de 2 Draining a Toilet Tank, Draining a Toilet Tank: étape 3, image 2 de 2
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
Most toilets retain a small amount of water in the tank after draining. To remove any excess water from the bottom of your toilet tank, use our guide for Sponge Drying a Toilet Tank.
Ron Davis
Membre depuis le 02/17/15
31 204 Réputation
13 tutoriels rédigés
2 commentaires
I have a cracking in my toilet tank going almost the length of the tank and below water line resulting in a leak. In your experience is a sealant a good option or in reality would the tank need to be replaced in time ?
Thanks
K EVANS - Réponse
It would make more sense to replace the tank, than seal any crack which would only reappear after time anyway.
John Turner -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 52
30 derniers jours : 235
Total : 32,301
