Introduction
This is a teardown guide for the handheld battery-operated vacuum cleaner Dreame T30.
Ce dont vous avez besoin
Use a T10 torx screwdriver to remove the screw.
Then use a prying tool of some sort (Jimmy) to loosen the latches.
Finally, remove it.
Remove the positive and negative leads of the suction fan from the pcba.
Disconnect the rest of the cables and remove the middle screw.
Once the screw is removed, push the PCBA out. Simply push on the battery connector.
Back up top, pull the 2 top wires through the gap.
You will now have to push the little grey button and the red trigger button in while applying some upwards pressure to loosen the handle.
Now, simply pull the handle out.
Rotate back to the front and remove the 2 marked screws. They're T10 Torx.
To remove the handle chassis, insert a prying tool into the marked gap.
Then, simply apply adequate force in the direction of the arrow.
Now, pull the chassis off, but only enough to expose the pcba and not any more.
Remove the small screw from the PCBA. It is a Torx T6.
Disconnect the cable from the PCBA, then pull the other cables through the gap in the PCBA.
Lead the cable out of the housing as you remove the chassis.
Remove the marked screws, then flip it over.
Unfold the foam filter out of the way, then remove the other 2 screws.
Remove the chassis by bending the transparent plastic out of the way, and unlatching the latches.
Then pull it off.
Remove the 5 screws.
There is still a latch holding it together at the front. Use a prying tool to unlatch it.
Once you remove the suction fan assembly, you can disassemble it by taking these 3 screws off.
All of the screws are sorted by steps and have the sizes written next to them. Use this as a reference during reassembly if needed.
4 commentaires de tutoriel
Great thanks! My power button was stuck, with your guide I quickly took the handle apart and sanded down the power button around the top part (It looks like there was a small friction groove from use, which caught the power button from time to time). Now it's back together and working perfectly, great guide, thanks a lot stranger!
I also had to perform work on the power button. Steps 1-8 worked perfectly to get access on my T20 model - light sanding to the red power button, and some padding behind the button.
possiedo dreame t30 a volte quando premo pulsante accensione non riescie a partireprende impulso si accende regolarmente display ma non parte a volte poi riparte e funziona potebbe essere pulsante? se qualcuno ha avuto stesso problema mi potrebbe dare qualche consiglio grazie
Tengo una Dreame T30, el motor de succión funciona correctamente, pero no funciona ninguno de los accesorios como cepillo principal, el de ácaros y el tubo con led. Algfuien podría ayudarme, gracias.
