Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Dreame Z10 Pro: Laser Distance Sensor Replacement
Ce dont vous avez besoin
    1. Dreame Z10 Pro: Laser Distance Sensor Replacement, Remove the front half of the top cover: étape 1, image 1 de 3 Dreame Z10 Pro: Laser Distance Sensor Replacement, Remove the front half of the top cover: étape 1, image 2 de 3 Dreame Z10 Pro: Laser Distance Sensor Replacement, Remove the front half of the top cover: étape 1, image 3 de 3
      • Grab it, then give it a firm tug.
      • The latches here are pretty tight.
      Demander à FixBot
      Ajouter un commentaire
    2. Dreame Z10 Pro: Laser Distance Sensor Replacement, Remove the back half of the top cover: étape 2, image 1 de 2 Dreame Z10 Pro: Laser Distance Sensor Replacement, Remove the back half of the top cover: étape 2, image 2 de 2
      • Remove the screws using a PH2 screwdriver, then the plastic tabs.
      • Then remove the back half of the top cover.
      Demander à FixBot
    3. Dreame Z10 Pro: Laser Distance Sensor Replacement, Remove the LDS cage: étape 3, image 1 de 3 Dreame Z10 Pro: Laser Distance Sensor Replacement, Remove the LDS cage: étape 3, image 2 de 3 Dreame Z10 Pro: Laser Distance Sensor Replacement, Remove the LDS cage: étape 3, image 3 de 3
      • Remove the rubber caps covering the screws.
      • Remove the screws. Use a PH00 screwdriver.
      Demander à FixBot
    4. Dreame Z10 Pro: Laser Distance Sensor Replacement, Remove the LDS: étape 4, image 1 de 2 Dreame Z10 Pro: Laser Distance Sensor Replacement, Remove the LDS: étape 4, image 2 de 2
      • Try not to lose these springs.
      • Remove the screws. Use a PH1 screwdriver.
      Demander à FixBot
    5. Dreame Z10 Pro: Laser Distance Sensor Replacement, Remove the LDS and replace it: étape 5, image 1 de 3 Dreame Z10 Pro: Laser Distance Sensor Replacement, Remove the LDS and replace it: étape 5, image 2 de 3 Dreame Z10 Pro: Laser Distance Sensor Replacement, Remove the LDS and replace it: étape 5, image 3 de 3
      • Take the LDS out and disconnect the connector.
      • Insert a new LDS in and close it up.
      Demander à FixBot
DegenFixer
Membre depuis le 09/18/24
5 750 Réputation
24 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 29
30 derniers jours : 166
Total : 2,370
