Aller au contenu principal
Dremel 7300 MiniMite Cordless Collet Replacement
Ce dont vous avez besoin
  1. Dremel 7300 MiniMite Cordless Collet Replacement, Collet: étape 1, image 1 de 3 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: étape 1, image 2 de 3 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: étape 1, image 3 de 3
    • The device comes with a small black wrench to tighten the collet nut, during reassembly or changing the bits.
    • Press the blue button and hold it down.
    • Unscrew the collet nut, with your fingers (as if you were going to change the bit).
    • Continue until the collet nut comes completely off of the Dremel.
  2. Dremel 7300 MiniMite Cordless Collet Replacement: étape 2, image 1 de 3 Dremel 7300 MiniMite Cordless Collet Replacement: étape 2, image 2 de 3 Dremel 7300 MiniMite Cordless Collet Replacement: étape 2, image 3 de 3
    • Once the collet nut is off, you can remove the collet. It is the silver part that grips the bit when the collet nut tightens on it.
    • The collet itself may be in the shaft, or come off with the nut.
7 autres ont terminé cette réparation.
Kat
Membre depuis le 02/10/16
840 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 3-4, Sullivan Spring 2016 Membre de l'équipe USF Tampa, Team 3-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G4
4 membres
4 tutoriels rédigés
2 commentaires
Too anyone having trouble unscrewing the collet, you may want to clamp vice grips on if its stuck tight. Worked for me.
Will - Réponse
I easily removed the bit by holding the blue button and using the black wrench to loosen it and then I remove the silver piece that holds the bit then when I tried to use another one of the attachments it seems like it’s too large to fit in there I haven’t been able to use any of the other attachments like polishing and the finer little grinders
Kate Denkers - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 17
Total : 32,528
