Introduction
This guide will show you how to replace a defective motor. With a few steps and a some tools, you will be able to open up the device and gain access to the motor. The motor can then be easily swapped out for a new one so that it can start working again.
Ce dont vous avez besoin
Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
4 autres ont terminé cette réparation.
3 commentaires
Have you ever taken apart the motor? If so how?
Is there polarity correctness of the motor connections?
Yes cal, the +ve (red) wire connects to the spade marked with a red dot.
