Aller au contenu principal
Dremel MultiPro 395 Casing Replacement
Ce dont vous avez besoin
  1. Dremel MultiPro 395 Casing Replacement, Casing: étape 1, image 1 de 2 Dremel MultiPro 395 Casing Replacement, Casing: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    J'achète
    • Remove the blue caps located on either side of the MultiPro, using a 3 mm flathead screwdriver.
  2. Dremel MultiPro 395 Casing Replacement: étape 2, image 1 de 2 Dremel MultiPro 395 Casing Replacement: étape 2, image 2 de 2
    • Carefully remove the carbon brushes attached at the end of the springs by gently pulling on the springs using your hands.
  3. Dremel MultiPro 395 Casing Replacement: étape 3, image 1 de 2 Dremel MultiPro 395 Casing Replacement: étape 3, image 2 de 2
    • Pull one side of the hanger up and then pull away from the Multipro until the other side can be pulled out.
  4. Dremel MultiPro 395 Casing Replacement: étape 4, image 1 de 3 Dremel MultiPro 395 Casing Replacement: étape 4, image 2 de 3 Dremel MultiPro 395 Casing Replacement: étape 4, image 3 de 3
    • Remove the 4 screws located on the bottom of the Multipro with a T15 screwdriver.
  5. Dremel MultiPro 395 Casing Replacement: étape 5, image 1 de 3 Dremel MultiPro 395 Casing Replacement: étape 5, image 2 de 3 Dremel MultiPro 395 Casing Replacement: étape 5, image 3 de 3
    • Hold down the collet lock, remove the chuck cap from the top of the Multipro by screwing counterclockwise.
  6. Dremel MultiPro 395 Casing Replacement: étape 6, image 1 de 3 Dremel MultiPro 395 Casing Replacement: étape 6, image 2 de 3 Dremel MultiPro 395 Casing Replacement: étape 6, image 3 de 3
    • Remove the black housing cap from the Multipro located directly below the chuck cap.
  7. Dremel MultiPro 395 Casing Replacement: étape 7, image 1 de 3 Dremel MultiPro 395 Casing Replacement: étape 7, image 2 de 3 Dremel MultiPro 395 Casing Replacement: étape 7, image 3 de 3
    • Pull the bottom side of the casing up to remove it.
  8. Dremel MultiPro 395 Casing Replacement: étape 8, image 1 de 3 Dremel MultiPro 395 Casing Replacement: étape 8, image 2 de 3 Dremel MultiPro 395 Casing Replacement: étape 8, image 3 de 3
    • Gently lift the motor shaft out of the Multipro.
  9. Dremel MultiPro 395 Casing Replacement: étape 9, image 1 de 3 Dremel MultiPro 395 Casing Replacement: étape 9, image 2 de 3 Dremel MultiPro 395 Casing Replacement: étape 9, image 3 de 3
    • Pull the lock pin and its casing out of the other side of the Multipro case.
2 autres ont terminé cette réparation.
Matthew Satton
Membre depuis le 09/17/14
520 Réputation
2 tutoriels rédigés
Équipe
Un commentaire
A link to parts is always nice,
bari - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 17
Total : 2,124
