Aller au contenu principal
Drill Master Heat Gun Power Switch Replacement
Ce dont vous avez besoin
  1. Drill Master Heat Gun Power Switch Replacement, Power Switch: étape 1, image 1 de 1
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Power Switch Replacement: étape 2, image 1 de 1
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Power Switch Replacement: étape 3, image 1 de 3 Drill Master Heat Gun Power Switch Replacement: étape 3, image 2 de 3 Drill Master Heat Gun Power Switch Replacement: étape 3, image 3 de 3
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Power Switch Replacement: étape 4, image 1 de 1
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Power Switch Replacement: étape 5, image 1 de 1
    • Loosen four screws on the wire connector using the flathead 2.5 screwdriver.
    • Screws do not come out of connector.
  6. Drill Master Heat Gun Power Switch Replacement: étape 6, image 1 de 1
    • Squeeze the tabs on either side of the power switch to remove from the casing.
  7. Drill Master Heat Gun Power Switch Replacement: étape 7, image 1 de 2 Drill Master Heat Gun Power Switch Replacement: étape 7, image 2 de 2
    • Remove the black, plastic wire protectors from the end of the power switch.
  8. Drill Master Heat Gun Power Switch Replacement: étape 8, image 1 de 1
    • Use soldering iron to remove the electrical wiring from the power switch. To replace the power switch, solder the new switch onto the wires.
    • Heating the soldering metal will allow you to pull off the electrical wiring.
    • For a brush-up on proper soldering, check out How to Solder and Desolder Connections.
Mikayla Kim
Membre depuis le 01/31/17
523 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 27
Total : 2,800
