Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
How to replace the Power Switch
  1. To start getting the case off remove the front panel so it's out of the way.
    • To start getting the case off remove the front panel so it's out of the way.
  2. Next remove the screws from the feet of the case with a phillips head screwdriver. Next remove the screws from the feet of the case with a phillips head screwdriver.
    • Next remove the screws from the feet of the case with a phillips head screwdriver.
  3. To remove the case, place the Drobo on its back and slide the case off.
    • To remove the case, place the Drobo on its back and slide the case off.
  4. Press tabs to release back cover and lift off Press tabs to release back cover and lift off Press tabs to release back cover and lift off
    • Press tabs to release back cover and lift off
  5. Push tabs in and carefully pull out the front facer and drive shelves Push tabs in and carefully pull out the front facer and drive shelves
    • Push tabs in and carefully pull out the front facer and drive shelves
  6. Unscrew the back face by removing the screw on the back sides, then slide top face apart from the others Unscrew the back face by removing the screw on the back sides, then slide top face apart from the others
    • Unscrew the back face by removing the screw on the back sides, then slide top face apart from the others
  7. Carefully unplug the Power Switch and Fan wires. Carefully unplug the Power Switch and Fan wires.
    • Carefully unplug the Power Switch and Fan wires.
  8. Press tabs on Power Switch to release the Power Switch and Push out.
    • Press tabs on Power Switch to release the Power Switch and Push out.
    • A Spudger like object is helpful for pushing in the tabs if the fan is not removed also
  9. Finally pull the old switch out and pop the new one in. Finally pull the old switch out and pop the new one in.
    • Finally pull the old switch out and pop the new one in.
Rye Cassan
Membre depuis le 24/01/2017
128 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 10-4, Banghart Winter 2017 Membre de l'équipe Cal Poly, Team 10-4, Banghart Winter 2017
CPSU-BANGHART-W17S10G4
3 membres
5 tutoriels rédigés
Hello,
great info I found here, but where do I buy a replacement button for my Drobo in Europe?
Kind regards and thank you in advance,
Heinrich
Heinrich Voelkel - Réponse
Hi, where do I find a replacement power switch for my Drobo 5N? BTW, thanks for the great tutorial!
Stephen R Parrott - Réponse
I took my Drobo apart and the printed numbers on the switch are R13-112. I ordered these on Amazon:
https://www.amazon.com/Twidec-Rocker-Tog...
I put it in, crossed my fingers, and BAM, worked like a charm. Hope that helps all the future DIY’ers.
tdubs - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 15
Total : 935
