Aller au contenu principal
Drum Head Replacement
Ce dont vous avez besoin
  1. Drum Head Replacement, Drum Head: étape 1, image 1 de 1
    • Loosen the tension rods until all rods are free from the drum.
    • The tension rods are universal for all drums and drum sets.
  2. Drum Head Replacement: étape 2, image 1 de 1
    • Remove the rim and drum head.
    • Keep track of the tension rods by leaving them in their holders on the rim.
  3. Drum Head Replacement: étape 3, image 1 de 1
    • Put on the new drum head first.
    • Put the rim on, making sure that the tension rods are properly aligned.
  4. Drum Head Replacement: étape 4, image 1 de 1
    • Tighten the tension rods with your fingers until you begin to feel tension.
    • You do not want them completely tightened yet. You just want to make sure the head is not wrinkled.
  5. Drum Head Replacement: étape 5, image 1 de 3 Drum Head Replacement: étape 5, image 2 de 3 Drum Head Replacement: étape 5, image 3 de 3
    • Begin to tighten the tension rods in a star pattern using a drum key.
    • Do not tighten the tension rods in a clockwise or counter clockwise pattern.
    • Tighten the rods until you find the sound you want from the drum.
  6. Drum Head Replacement: étape 6, image 1 de 1
    • While tightening the tension rods, tap a drumstick on the drum head about an inch from the tension rods.
    • This is how you will determine which tension rods need to be tightened, loosened, or left alone.
  7. Drum Head Replacement: étape 7, image 1 de 3 Drum Head Replacement: étape 7, image 2 de 3 Drum Head Replacement: étape 7, image 3 de 3
    • Once you have found the sound you like and the drum is in tune, push around the middle of the drum head, moving around the drum.
    • Repeat Steps 6 and 7 until the drum is in tune again.
Daniel Barry
Membre depuis le 11/28/21
145 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 16
Total : 191
