Aller au contenu principal
Dryer Power Cord Replacement
Ce dont vous avez besoin
  1. Dryer Power Cord Replacement, Dryer Power Cord: étape 1, image 1 de 3 Dryer Power Cord Replacement, Dryer Power Cord: étape 1, image 2 de 3 Dryer Power Cord Replacement, Dryer Power Cord: étape 1, image 3 de 3
    • Before starting this guide, TURN OFF THE BREAKER SWITCH related to the dryer.
    • Doing this will help to avoid bodily harm, and also protect the wires from shorting out.
    • Locate your breaker box - (Some are outside and some are inside the house).
    • Once it is found, find the dryer switch and push it to the LEFT to turn it off.
  2. Dryer Power Cord Replacement: étape 2, image 1 de 3 Dryer Power Cord Replacement: étape 2, image 2 de 3 Dryer Power Cord Replacement: étape 2, image 3 de 3
    • Unplug the dryer from the wall.
    • Use a screwdriver to remove any screws that secure the power cord cover.
  3. Dryer Power Cord Replacement: étape 3, image 1 de 2 Dryer Power Cord Replacement: étape 3, image 2 de 2
    • Remove the panel by sliding it to the LEFT.
  4. Dryer Power Cord Replacement: étape 4, image 1 de 1
    • Now that the panel is off, you can see the wires needed to be replaced.
    • The configuration of the wires are power at the top (Usually represented as RED or BLACK)
    • The ground wire is in the middle (Usually represented as WHITE)
    • The bottom wire is also a power wire also (Usually represented as RED or BLACK)
  5. Dryer Power Cord Replacement: étape 5, image 1 de 3 Dryer Power Cord Replacement: étape 5, image 2 de 3 Dryer Power Cord Replacement: étape 5, image 3 de 3
    • Remove the screws that hold the three wires in place.
  6. Dryer Power Cord Replacement: étape 6, image 1 de 2 Dryer Power Cord Replacement: étape 6, image 2 de 2
    • You should now be able to remove the power cord freely.
  7. Dryer Power Cord Replacement: étape 7, image 1 de 2 Dryer Power Cord Replacement: étape 7, image 2 de 2
    • Now remove the green screw in order to remove the grounding bracket.
  8. Dryer Power Cord Replacement: étape 8, image 1 de 3 Dryer Power Cord Replacement: étape 8, image 2 de 3 Dryer Power Cord Replacement: étape 8, image 3 de 3
    • With everything removed, you can now bring in your new 4 prong power cord.
    • Unlike the old power cord, the new power cord should have the color of what type of wire it is (ex. red for power and white for ground).
    • You can start screwing in the wires with the removed screws from the old cord to the new RED WIRE at the TOP.
    • With the WHITE WIRE, grab the gold plate and put it on top of the wire. Grab the screw and put it on top of the gold plate and screw it in the MIDDLE.
  9. Dryer Power Cord Replacement: étape 9, image 1 de 3 Dryer Power Cord Replacement: étape 9, image 2 de 3 Dryer Power Cord Replacement: étape 9, image 3 de 3
    • Screw the BLACK WIRE at the BOTTOM regularly like the red wire.
    • You should have an extra green wire as this is placed where you saw the green screw in the beginning.
    • Grab the green wire and put it at the end of the gold plate and grab the green screw to screw it in for a tight connection.
  10. Dryer Power Cord Replacement: étape 10, image 1 de 3 Dryer Power Cord Replacement: étape 10, image 2 de 3 Dryer Power Cord Replacement: étape 10, image 3 de 3
    • Slide the panel back over the power cord and screw it back in.
  11. Dryer Power Cord Replacement: étape 11, image 1 de 2 Dryer Power Cord Replacement: étape 11, image 2 de 2
    • Plug your dryer back into the socket and go to your breaker box to turn the power back on.
    • You can now use your dryer in your new home.
    • If your dryer does not turn on check your breaker box to make sure it did not short your circuit. If so turn the breaker switch to the OFF position and check wiring connections.
To reassemble to the 3 prong configuration, follow these instructions in reverse order.
Ronnie Mitchell
Membre depuis le 09/29/21
193 Réputation
1 tutoriel rédigé
Équipe
University of Memphis, Team 1-7, Cameron Fall 2022 Membre de l'équipe University of Memphis, Team 1-7, Cameron Fall 2022
UM-CAMERON-F22S1G7
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 17
30 derniers jours : 49
Total : 533
