Aller au contenu principal
DualSense Edge Battery Replacement
Ce dont vous avez besoin
  1. DualSense Edge Battery Replacement, Battery: étape 1, image 1 de 2 DualSense Edge Battery Replacement, Battery: étape 1, image 2 de 2
    • Disconnect and power down your controller before you begin.
    • Use the opening pick to push the release latch on the back of the controller.
  2. DualSense Edge Battery Replacement: étape 2, image 1 de 3 DualSense Edge Battery Replacement: étape 2, image 2 de 3 DualSense Edge Battery Replacement: étape 2, image 3 de 3
    • Remove the front plate.
  3. DualSense Edge Battery Replacement: étape 3, image 1 de 2 DualSense Edge Battery Replacement: étape 3, image 2 de 2
    • Raise both left and right levers next to each stick module.
  4. DualSense Edge Battery Replacement: étape 4, image 1 de 3 DualSense Edge Battery Replacement: étape 4, image 2 de 3 DualSense Edge Battery Replacement: étape 4, image 3 de 3
    • Slide both stick modules out of their slots.
  5. DualSense Edge Battery Replacement: étape 5, image 1 de 3 DualSense Edge Battery Replacement: étape 5, image 2 de 3 DualSense Edge Battery Replacement: étape 5, image 3 de 3
    • Use the pick to pop both the R1 and L1 shoulder buttons out.
    • Use your thumb to prevent the button from flying across the room.
  6. DualSense Edge Battery Replacement: étape 6, image 1 de 2 DualSense Edge Battery Replacement: étape 6, image 2 de 2
    • Slide the opening pick along the left and right inner trim to release the clips that secure the case.
  7. DualSense Edge Battery Replacement: étape 7, image 1 de 3 DualSense Edge Battery Replacement: étape 7, image 2 de 3 DualSense Edge Battery Replacement: étape 7, image 3 de 3
    • Turn the controller around and continue sliding the opening pick along the trim to release the remaining clips.
  8. DualSense Edge Battery Replacement: étape 8, image 1 de 2 DualSense Edge Battery Replacement: étape 8, image 2 de 2
    • Remove the middle casing now that all clips are released.
  9. DualSense Edge Battery Replacement: étape 9, image 1 de 3 DualSense Edge Battery Replacement: étape 9, image 2 de 3 DualSense Edge Battery Replacement: étape 9, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the two 6.5 mm screws from the L1 and R1 button enclosures (one screw on each side).
  10. DualSense Edge Battery Replacement: étape 10, image 1 de 2 DualSense Edge Battery Replacement: étape 10, image 2 de 2
    • Use your screwdriver to remove the seven 6.5 mm screws from the back of the controller.
  11. DualSense Edge Battery Replacement: étape 11, image 1 de 2 DualSense Edge Battery Replacement: étape 11, image 2 de 2
    • Pull the lever to the left and lift up to detach it from the controller.
    • Be careful with the tiny spring attached to the lever, as it is easy to lose once detached.
  12. DualSense Edge Battery Replacement: étape 12, image 1 de 2 DualSense Edge Battery Replacement: étape 12, image 2 de 2
    • Insert an opening pick between the front and rear casing and gently pry them apart.
  13. DualSense Edge Battery Replacement: étape 13, image 1 de 3 DualSense Edge Battery Replacement: étape 13, image 2 de 3 DualSense Edge Battery Replacement: étape 13, image 3 de 3
    • Use your hands to pull the rear case off of the controller carefully.
    • Make sure to go from bottom to top when removing the case so as not to pull on the trigger buttons.
  14. DualSense Edge Battery Replacement: étape 14, image 1 de 2 DualSense Edge Battery Replacement: étape 14, image 2 de 2
    • Use your opening pick to lift the battery from its enclosure and expose the wire connection.
    • The battery is loose in the enclosure; hold the controller with the battery facing upward so it does not fall out.
  15. DualSense Edge Battery Replacement: étape 15, image 1 de 3 DualSense Edge Battery Replacement: étape 15, image 2 de 3 DualSense Edge Battery Replacement: étape 15, image 3 de 3
    • Place your opening pick under the wire housing, and pull it upward toward you to disconnect the battery.
Roberto Loya
Membre depuis le 04/01/23
257 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 1-1, Briggs Spring 2023 Membre de l'équipe CSU Los Angeles, Team 1-1, Briggs Spring 2023
CSULA-BRIGGS-S23S1G1
2 membres
3 tutoriels rédigés
2 commentaires
where can i buy battery replacement
Rave Paz - Réponse
取替の説明が有っても、バッテリー自体が手に入らないから日本では上げても余り意味が無い。
ちょいオヤジ - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 25
7 derniers jours : 155
30 derniers jours : 878
Total : 7,460
