Aller au contenu principal
Pour réparer ensemble - Je crée un compte
DualSense Edge Joysticks Replacement
Ce dont vous avez besoin
    1. DualSense Edge Joysticks Replacement, Remove the front trim: étape 1, image 1 de 3 DualSense Edge Joysticks Replacement, Remove the front trim: étape 1, image 2 de 3 DualSense Edge Joysticks Replacement, Remove the front trim: étape 1, image 3 de 3
      • Place the controller on a work surface with the joysticks facing down.
      • Use a spudger or your finger to slide the Release tab to the left. The front trim should fall to the table.
      • If the front trim doesn't fall open, make sure the front trim has room to fall down and the Release tab is pushed all the way to the left.
      • Lift the controller up, leaving the front trim on the table.
      • During reassembly, insert the front trim at an angle so the top slots in first, then lower the trim into place and snap it onto the controller.
      Demander à FixBot
      Ajouter un commentaire
    1. DualSense Edge Joysticks Replacement, Remove the joysticks: étape 2, image 1 de 3 DualSense Edge Joysticks Replacement, Remove the joysticks: étape 2, image 2 de 3 DualSense Edge Joysticks Replacement, Remove the joysticks: étape 2, image 3 de 3
      • Flip the controller over so the joysticks are facing up.
      • Lift the metal lever that holds the joystick in place until the joystick slides out slightly.
      • Slide the joystick out from its slot.
      Demander à FixBot
    2. DualSense Edge Joysticks Replacement: étape 3, image 1 de 1
      • Repeat this process to remove the other joystick.
      Demander à FixBot
6 autres ont terminé cette réparation.
Spencer Pennington
Membre depuis le 09/09/23
26 888 Réputation
126 tutoriels rédigés
Équipe
Guide Team Membre de l'équipe Guide Team
Staff
10 membres
49 290 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 29
7 derniers jours : 193
30 derniers jours : 735
Total : 14,820
