Aller au contenu principal
Pour réparer ensemble - Je crée un compte
DualSense Edge Rear Trim Replacement
Ce dont vous avez besoin
    1. DualSense Edge Rear Trim Replacement, Remove the front trim: étape 1, image 1 de 3 DualSense Edge Rear Trim Replacement, Remove the front trim: étape 1, image 2 de 3 DualSense Edge Rear Trim Replacement, Remove the front trim: étape 1, image 3 de 3
      • Place the controller on a work surface with the joysticks facing down.
      • Use a spudger or your finger to slide the Release tab to the left. The front trim should fall to the table.
      • If the front trim doesn't fall open, make sure the front trim has room to fall down and the Release tab is pushed all the way to the left.
      • Lift the controller up, leaving the front trim on the table.
      • During reassembly, insert the front trim at an angle so the top slots in first, then lower the trim into place and snap it onto the controller.
      Demander à FixBot
      Ajouter un commentaire
    1. DualSense Edge Rear Trim Replacement, Remove the joysticks: étape 2, image 1 de 3 DualSense Edge Rear Trim Replacement, Remove the joysticks: étape 2, image 2 de 3 DualSense Edge Rear Trim Replacement, Remove the joysticks: étape 2, image 3 de 3
      • Flip the controller over so the joysticks are facing up.
      • Lift the metal lever that holds the joystick in place until the joystick slides out slightly.
      • Slide the joystick out from its slot.
      Demander à FixBot
    2. DualSense Edge Rear Trim Replacement: étape 3, image 1 de 1
      • Repeat this process to remove the other joystick.
      Demander à FixBot
    1. DualSense Edge Rear Trim Replacement, Insert an opening pick: étape 4, image 1 de 3 DualSense Edge Rear Trim Replacement, Insert an opening pick: étape 4, image 2 de 3 DualSense Edge Rear Trim Replacement, Insert an opening pick: étape 4, image 3 de 3
      • The rear trim is held in place by fragile plastic clips. Work slowly and gently to avoid breaking the clips.
      • If you installed the back button paddles included with your controller, remove them before beginning this process.
      • Insert the flat edge of an opening pick between the black portion of the rear trim and the top cover, near the joystick lever.
      • Slide the opening pick towards the bottom of the grip to release the clips.
      Demander à FixBot
    2. DualSense Edge Rear Trim Replacement, Release the clips: étape 5, image 1 de 2 DualSense Edge Rear Trim Replacement, Release the clips: étape 5, image 2 de 2
      • Slide the pick around to the rear of the controller and flip the controller over so the buttons are facing down.
      • Slide the opening pick around the edge of the rear trim to release the clips.
      Demander à FixBot
    3. DualSense Edge Rear Trim Replacement, Remove the rear trim: étape 6, image 1 de 3 DualSense Edge Rear Trim Replacement, Remove the rear trim: étape 6, image 2 de 3 DualSense Edge Rear Trim Replacement, Remove the rear trim: étape 6, image 3 de 3
      • Slide the opening along the edge of the trim on the other grip.
      • Once all clips are released, remove the trim.
      • If at any point the trim feels stuck, stop and look for any clips that may have re-engaged and release them with the opening pick to avoid damaging them.
      Demander à FixBot
Spencer Pennington
Membre depuis le 09/09/23
26 888 Réputation
126 tutoriels rédigés
Équipe
Guide Team Membre de l'équipe Guide Team
Staff
10 membres
46 498 tutoriels rédigés
3 commentaires de tutoriel
Wo kann man eine Zierblende kaufen?
Nic Ley - Réponse Partager
wo kann ich die Zierblende kaufen?
Marco Oelze - Réponse Partager
Hallo, ich bin ebenfalls auf der Suche nach einer neuen rückseitige Zierblende. Am liebsten offiziell von Playstation. Ansonsten auch gerne von anderen Anbietern mit guter Qualität.
Robin - Réponse Partager
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 89
30 derniers jours : 359
Total : 7,364
