Aller au contenu principal
DualShock 3 Front Shell Cover Replacement
Ce dont vous avez besoin
  1. DualShock 3 Front Shell Cover Replacement, Front Shell Cover.: étape 1, image 1 de 2 DualShock 3 Front Shell Cover Replacement, Front Shell Cover.: étape 1, image 2 de 2
    • Flip the controller over and locate the five 7.2mm Phillips #0 screws securing the rear cover to the front cover.
  2. DualShock 3 Front Shell Cover Replacement: étape 2, image 1 de 3 DualShock 3 Front Shell Cover Replacement: étape 2, image 2 de 3 DualShock 3 Front Shell Cover Replacement: étape 2, image 3 de 3
    • Using the Phillips #0 screwdriver, remove the five screws holding the rear/back cover in place.
  3. DualShock 3 Front Shell Cover Replacement: étape 3, image 1 de 2 DualShock 3 Front Shell Cover Replacement: étape 3, image 2 de 2
    • Gently lift the rear cover away from the rest of the controller starting from the bottom side adjacent to the analog stick controllers.
    • Push gently by sliding the rear back forward towards the top edge of the dual shock controller to prevent tripping the two bottom triggers labelled (2).
  4. DualShock 3 Front Shell Cover Replacement: étape 4, image 1 de 1
    • Lift the rear cover off of the controller to expose the interior.
  5. DualShock 3 Front Shell Cover Replacement: étape 5, image 1 de 3 DualShock 3 Front Shell Cover Replacement: étape 5, image 2 de 3 DualShock 3 Front Shell Cover Replacement: étape 5, image 3 de 3
    • Carefully detach or disconnect the lithium polymer battery from the motherboard.
    • The wires are fragile, be careful not to break them when pulling out the battery as they can break easily.
  6. DualShock 3 Front Shell Cover Replacement: étape 6, image 1 de 3 DualShock 3 Front Shell Cover Replacement: étape 6, image 2 de 3 DualShock 3 Front Shell Cover Replacement: étape 6, image 3 de 3
    • Use the Phillips #0 screwdriver to remove five 7.2 mm screws from the motherboard.
    • Lift the motherboard, vibration motors and analog module joysticks pads all in one connection, away from the shell.
  7. DualShock 3 Front Shell Cover Replacement: étape 7, image 1 de 2 DualShock 3 Front Shell Cover Replacement: étape 7, image 2 de 2
    • Carefully lift the rubber or plastic part holding the button triggers labelled (2) in place.
    • Be careful not to strip the plastic rubber holding the triggers in place.
    • Slide the trigger button retainers away from the front shell. Set them aside.
  8. DualShock 3 Front Shell Cover Replacement: étape 8, image 1 de 1
    • Set aside the colored buttons and lift the white rubber part holding the Dpad buttons in place to securely remove it.
4 autres ont terminé cette réparation.
Joseph Wambui
Membre depuis le 07/09/21
253 Réputation
1 tutoriel rédigé
Équipe
York University, Team 1-28, O'Regan Fall 2021 Membre de l'équipe York University, Team 1-28, O'Regan Fall 2021
YORK-O'REGAN-F21S1G28
1 membre
2 tutoriels rédigés
2 commentaires
Personally I believe with the current price of a DualShock 3 controller its not even worth it to replace the following parts. Or maybe its just me? Sony has done a great product and will continue to do so!
Andrew McMason - Réponse
The original 6 axis controller I got with my PS3 back in the day has different size screws than the gold plated one I got a few years later. They're about 3 mm longer too
Gregory Hedges - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 40
30 derniers jours : 156
Total : 3,617
