Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Pièces
Aucune pièce spécifiée.
  1. Remove the single 7.2 mm Phillips screw securing the motherboard to the front cover.
    • Remove the single 7.2 mm Phillips screw securing the motherboard to the front cover.
  2. Slide the trigger button retainers slightly away from the front cover. Remove the #1 button on both sides. Remove the #1 button on both sides.
    • Slide the trigger button retainers slightly away from the front cover.
    • Remove the #1 button on both sides.
  3. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  4. Pull the vibration motor retainers away from the front cover to dislodge the motherboard assembly. Pull the vibration motor retainers away from the front cover to dislodge the motherboard assembly.
    • Pull the vibration motor retainers away from the front cover to dislodge the motherboard assembly.
  5. Remove the motherboard assembly from the front cover.
    • Remove the motherboard assembly from the front cover.
    • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,507
