Aller au contenu principal
DualShock 4 CHU-ZCT2U Disassembly
Ce dont vous avez besoin
  1. DualShock 4 CHU-ZCT2U Disassembly, First Screws: étape 1, image 1 de 2 DualShock 4 CHU-ZCT2U Disassembly, First Screws: étape 1, image 2 de 2
    • All the screws are the same in the controller (Phillips's head).
  2. DualShock 4 CHU-ZCT2U Disassembly, Opening the Case: étape 2, image 1 de 1
    • Use a plastic spudger to open the case. Try not to scratch the plastic.
  3. DualShock 4 CHU-ZCT2U Disassembly, Separate the 2 halves: étape 3, image 1 de 2 DualShock 4 CHU-ZCT2U Disassembly, Separate the 2 halves: étape 3, image 2 de 2
    • Be careful opening the case because there is a ribbon cable holding the 3 halves together.
    • The plastic for the lightbar will look different from mine because it's fragile and it broke.
  4. DualShock 4 CHU-ZCT2U Disassembly, Battery: étape 4, image 1 de 2 DualShock 4 CHU-ZCT2U Disassembly, Battery: étape 4, image 2 de 2
    • Remove the battery and the screw underneath it.
  5. DualShock 4 CHU-ZCT2U Disassembly, Touchpad Ribbon Cable: étape 5, image 1 de 1
    • The ribbon cable slots through the rectangular hole in the plastic beneath.
  6. DualShock 4 CHU-ZCT2U Disassembly, Board: étape 6, image 1 de 1
    • Remove the board.
  7. DualShock 4 CHU-ZCT2U Disassembly, You Are Done!: étape 7, image 1 de 1
    • You're finished with your DualShock 4 dissasembly!
To reassemble your device, follow these instructions in reverse order. If there are any issues, please tell me as this is my first guide
8 autres ont terminé cette réparation.
Mintyboi 88
Membre depuis le 04/17/20
316 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 21
7 derniers jours : 71
30 derniers jours : 391
Total : 12,782
