Aller au contenu principal
DualShock 4 CHU-ZCT2U Joystick Covers Replacement
Ce dont vous avez besoin
  1. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the rear panel screws: étape 1, image 1 de 2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the rear panel screws: étape 1, image 2 de 2
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
  2. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Separate the rear panel: étape 2, image 1 de 2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Separate the rear panel: étape 2, image 2 de 2
    • Four fragile plastic clips hold the panels together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
  3. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Release the plastic clips: étape 3, image 1 de 3 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Release the plastic clips: étape 3, image 2 de 3 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Release the plastic clips: étape 3, image 3 de 3
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
  4. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the rear panel: étape 4, image 1 de 2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the rear panel: étape 4, image 2 de 2
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
  5. DualShock 4 CHU-ZCT2U Joystick Covers Replacement: étape 5, image 1 de 2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement: étape 5, image 2 de 2
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
  6. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the battery: étape 6, image 1 de 2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the battery: étape 6, image 2 de 2
    • Use a pair of tweezers to pull the battery's power connector straight up from the motherboard.
  7. DualShock 4 CHU-ZCT2U Joystick Covers Replacement: étape 7, image 1 de 2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement: étape 7, image 2 de 2
    • Remove the battery.
  8. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the motherboard: étape 8, image 1 de 2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the motherboard: étape 8, image 2 de 2
    • Use a Phillips screwdriver to remove the 6.4 mm-long screw securing the battery bracket.
  9. DualShock 4 CHU-ZCT2U Joystick Covers Replacement: étape 9, image 1 de 2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement: étape 9, image 2 de 2
    • Remove the battery bracket.
  10. DualShock 4 CHU-ZCT2U Joystick Covers Replacement: étape 10, image 1 de 2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement: étape 10, image 2 de 2
    • Use a pair of tweezers to disconnect the touch panel ribbon cable.
    • Pull the ribbon cable directly away from its connector on the motherboard by the blue pull tab, not by the cable itself.
  11. DualShock 4 CHU-ZCT2U Joystick Covers Replacement: étape 11, image 1 de 2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement: étape 11, image 2 de 2
    • Separate the motherboard and midframe assembly from the front panel.
  12. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the joystick covers: étape 12, image 1 de 2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the joystick covers: étape 12, image 2 de 2
    • Pull the right joystick cover straight off the joystick module to remove it.
  13. DualShock 4 CHU-ZCT2U Joystick Covers Replacement: étape 13, image 1 de 2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement: étape 13, image 2 de 2
    • Pull the left joystick cover straight off the joystick module to remove it.
  14. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Reassembly tip: étape 14, image 1 de 2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Reassembly tip: étape 14, image 2 de 2
    • During reassembly, ensure the new joystick covers properly align with the shafts on the joystick modules before pressing them into place.
30 autres ont terminé cette réparation.
Sam Omiotek
Membre depuis le 02/25/19
72 472 Réputation
288 tutoriels rédigés
Un commentaire
Are you able to replace the actual joystick with a diffrent one or are we only able to switch out covers?
Grant seward - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 112
30 derniers jours : 356
Total : 17,461
