Aller au contenu principal
DualShock 4 CUH-ZCT1 Charging Port Replacement
Ce dont vous avez besoin
  1. DualShock 4 CUH-ZCT1 Charging Port Replacement, Charging Port: étape 1, image 1 de 1
    • Flip the Dualshock 4 controller on its back, and use a Phillips #00 screwdriver to remove the four 6 mm screws.
  2. DualShock 4 CUH-ZCT1 Charging Port Replacement: étape 2, image 1 de 1
    • Slowly lift the backplate onto the front side of the controller making sure not to fully remove the backplate.
  3. DualShock 4 CUH-ZCT1 Charging Port Replacement: étape 3, image 1 de 2 DualShock 4 CUH-ZCT1 Charging Port Replacement: étape 3, image 2 de 2
    • Remove the ribbon cable from the motherboard of the controller and place the top half of the controller on the side for later.
  4. DualShock 4 CUH-ZCT1 Charging Port Replacement: étape 4, image 1 de 1
    • Remove the light bar's sub-assembly by gently lifting up the piece.
  5. DualShock 4 CUH-ZCT1 Charging Port Replacement: étape 5, image 1 de 1
    • Lift the clear plastic piece out of the controller by pulling into the controller and removing it.
  6. DualShock 4 CUH-ZCT1 Charging Port Replacement: étape 6, image 1 de 1
    • Remove the two 6 mm Phillips screws that are on top of the PCB of the charging port.
  7. DualShock 4 CUH-ZCT1 Charging Port Replacement: étape 7, image 1 de 2 DualShock 4 CUH-ZCT1 Charging Port Replacement: étape 7, image 2 de 2
    • Gently wiggle the charging port's PCB side to side until it detaches from the controller.
7 autres ont terminé cette réparation.
Andy Lam
Membre depuis le 01/31/23
307 Réputation
1 tutoriel rédigé
Équipe
York University, Team P-10, Allen Fall 2022 Membre de l'équipe York University, Team P-10, Allen Fall 2022
YORK-ALLEN-F22SPG10
1 membre
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 73
30 derniers jours : 269
Total : 3,215
