Introduction
This guide provides a step-by-step process of how to replace a charging port in the DualShock 4 controller.
Ce dont vous avez besoin
Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons:
Share button
Options button
Split the plastic covers of the controller apart, taking note that they will still be attached by circuit board ribbons.
2 Trigger Springs
1 Grey Reset Button Extension
Detach the motherboard ribbon connecting the two sides of the controller by using your fingers.
After the two halves are separated, place the top of the controller off to the side.
94 autres ont terminé cette réparation.
32 commentaires
Looking for a new charging port .?
