Aller au contenu principal
DualShock 4 Controller Rumble Motors Replacement
Ce dont vous avez besoin
  1. DualShock 4 Controller Rumble Motors Replacement, Rumble Motors: étape 1, image 1 de 1
    • Remove the four 2mm screws on the rear plate using the #000 Phillips screwdriver.
  2. DualShock 4 Controller Rumble Motors Replacement: étape 2, image 1 de 1
    • Remove the rear plate.
    • We recommend using a metal spudger for this step.
  3. DualShock 4 Controller Rumble Motors Replacement: étape 3, image 1 de 2 DualShock 4 Controller Rumble Motors Replacement: étape 3, image 2 de 2
    • Desolder the joints that attach the rumble motors to the motherboard.
    • For more information on soldering, click here.
  4. DualShock 4 Controller Rumble Motors Replacement: étape 4, image 1 de 2 DualShock 4 Controller Rumble Motors Replacement: étape 4, image 2 de 2
    • There is a hidden screw underneath the battery pack that attaches the faceplate to the motherboard.
    • Lift the pack and remove the 10mm screw using the #000 Phillips screwdriver.
  5. DualShock 4 Controller Rumble Motors Replacement: étape 5, image 1 de 1
    • Remove the faceplate from the motherboard.
  6. DualShock 4 Controller Rumble Motors Replacement: étape 6, image 1 de 3 DualShock 4 Controller Rumble Motors Replacement: étape 6, image 2 de 3 DualShock 4 Controller Rumble Motors Replacement: étape 6, image 3 de 3
    • With some added pressure, push down and outward in order to free and remove the rumble motors from their socket.
13 autres ont terminé cette réparation.
Pedro Rodriguez
Membre depuis le 02/22/18
515 Réputation
1 tutoriel rédigé
Équipe
2 commentaires
I’d recommend adding removal instructions for the touchpad also
AlexMorse - Réponse
the rumble packs are stuck with an adhesive on my controller. The best way to remove the rumble pack in this case? thanks
Ka Erd - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 56
30 derniers jours : 289
Total : 25,059
