Aller au contenu principal
Durofix RV332 Battery Replacement
Ce dont vous avez besoin
  1. Durofix RV332 Battery Replacement, Battery: étape 1, image 1 de 3 Durofix RV332 Battery Replacement, Battery: étape 1, image 2 de 3 Durofix RV332 Battery Replacement, Battery: étape 1, image 3 de 3
    • Remove the six 13mm case screws with a #0 phillips screwdriver.
    • Separate the screwdriver housing with a plastic opening tool.
    • Remove battery casing half to expose screwdriver internals.
  2. Durofix RV332 Battery Replacement: étape 2, image 1 de 2 Durofix RV332 Battery Replacement: étape 2, image 2 de 2
    • Locate battery
    • Remove battery, printed circuit board, LED, and motor assembly from screwdriver casing.
  3. Durofix RV332 Battery Replacement: étape 3, image 1 de 1
    • Using side cutters, cut the red and black wires connecting the battery to the printed circuit board just after the shrink wrap tubing.
    • Strip the ends of the wires attached to the printed circuit board 1/4 inch above the ends of the cut wires.
    • Solder the new battery to the stripped wires attached to the printed circuit board.
    • Wrap the newly soldered connections with electrical tape.
2 autres ont terminé cette réparation.
Brennan Wade
Membre depuis le 02/21/14
122 Réputation
1 tutoriel rédigé
Équipe
Michigan Tech, Team 5-5, Lauer Spring 2014 Membre de l'équipe Michigan Tech, Team 5-5, Lauer Spring 2014
MTU-LAUER-S14S5G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 7
Total : 2,635
