Aller au contenu principal
Dymo LabelManager 160 Charging Port Replacement
Ce dont vous avez besoin
  1. Dymo LabelManager 160 Charging Port Replacement, Batteries: étape 1, image 1 de 1
    • Place the device face-down to access the battery compartment.
  2. Dymo LabelManager 160 Charging Port Replacement: étape 2, image 1 de 1
    • Remove the compartment cover to reveal the batteries. Remove the 6 old batteries.
  3. Dymo LabelManager 160 Charging Port Replacement, Keyboard: étape 3, image 1 de 1
    • To open the cartridge compartment, simply lift on the front of the device.
  4. Dymo LabelManager 160 Charging Port Replacement: étape 4, image 1 de 2 Dymo LabelManager 160 Charging Port Replacement: étape 4, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the four 1.3mm screws from the cartridge compartment and two 1.2mm screws from the battery compartment.
  5. Dymo LabelManager 160 Charging Port Replacement: étape 5, image 1 de 1
    • Using a spudger or other tool, lift and remove the front of the device. This should be done all around the device to ensure the two parts split correctly.
  6. Dymo LabelManager 160 Charging Port Replacement: étape 6, image 1 de 3 Dymo LabelManager 160 Charging Port Replacement: étape 6, image 2 de 3 Dymo LabelManager 160 Charging Port Replacement: étape 6, image 3 de 3
    • Gently remove the rubber keyboard from the device.
  7. Dymo LabelManager 160 Charging Port Replacement, Charging Port: étape 7, image 1 de 1
    • Use wire cutters or scissors to cut the wires attached to the charging port, and remove the charging port.
  8. Dymo LabelManager 160 Charging Port Replacement: étape 8, image 1 de 1
    • Use wire strippers to strip the end of each wire.
  9. Dymo LabelManager 160 Charging Port Replacement: étape 9, image 1 de 1
    • Solder the black wire to the bottom-most node of the new charging port. Solder the red wire to the uppermost node of the new charging port. See the following link for soldering tips: Comment souder et dessouder des connexions
Andrew Ozga
Membre depuis le 03/02/17
170 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S3-G4, Harley Spring 2017 Membre de l'équipe IUPUI, Team S3-G4, Harley Spring 2017
IUPUI-HARLEY-S17S3G4
4 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 888
