Aller au contenu principal
Dyson Ball Animal Power Button Replacement
Ce dont vous avez besoin
  1. Dyson Ball Animal Power Button Replacement, Power Button: étape 1, image 1 de 2 Dyson Ball Animal Power Button Replacement, Power Button: étape 1, image 2 de 2
    • Turn off and unplug the vacuum
  2. Dyson Ball Animal Power Button Replacement: étape 2, image 1 de 1
    • Press the red release button and pull the canister up and away.
  3. Dyson Ball Animal Power Button Replacement: étape 3, image 1 de 2 Dyson Ball Animal Power Button Replacement: étape 3, image 2 de 2
    • Locate the red dial at the back of the wand and turn counterclockwise to detach the wand.
  4. Dyson Ball Animal Power Button Replacement: étape 4, image 1 de 2 Dyson Ball Animal Power Button Replacement: étape 4, image 2 de 2
    • Remove the four 15mm screws behind the power button using a Torx T15 screwdriver.
  5. Dyson Ball Animal Power Button Replacement: étape 5, image 1 de 3 Dyson Ball Animal Power Button Replacement: étape 5, image 2 de 3 Dyson Ball Animal Power Button Replacement: étape 5, image 3 de 3
    • Use a spudger to push the two clamp tabs behind the power button towards the middle of the vacuum.
  6. Dyson Ball Animal Power Button Replacement: étape 6, image 1 de 2 Dyson Ball Animal Power Button Replacement: étape 6, image 2 de 2
    • Detach the power box case from the body of the Dyson after both clamps have been pushed out.
    • Upon removal of this case, you will be able to see a red circular power button.
  7. Dyson Ball Animal Power Button Replacement: étape 7, image 1 de 2 Dyson Ball Animal Power Button Replacement: étape 7, image 2 de 2
    • Gently pull the power button out of its slot as shown.
    • Detach the power button box from the two wires connecting it, and replace the faulty power button box with a functional one. The power button is the first black one.
4 autres ont terminé cette réparation.
Hank Wai
Membre depuis le 05/07/17
166 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S15-G5, Banghart Spring 2017 Membre de l'équipe Cal Poly, Team S15-G5, Banghart Spring 2017
CPSU-BANGHART-S17S15G5
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 50
Total : 6,633
