Introduction
If you have noticed the vacuum not performing as efficiently as it should and replacing the main filter did not help, the problem could be the side filter. Remove and replace the side filter often to ensure maximum results from your vacuum.
Twist the purple center circle counter clockwise until loose. This will leave the entire grey covering loosened.
2 autres ont terminé cette réparation.
