Aller au contenu principal
Dyson Cyclone V10 Absolute Motor Assembly Replacement
Ce dont vous avez besoin
  1. Dyson Cyclone V10 Absolute Motor Assembly Replacement, Motor Assembly: étape 1, image 1 de 3 Dyson Cyclone V10 Absolute Motor Assembly Replacement, Motor Assembly: étape 1, image 2 de 3 Dyson Cyclone V10 Absolute Motor Assembly Replacement, Motor Assembly: étape 1, image 3 de 3
    • Remove the extra parts of the vacuum, including the filter and the bin.
    • Press the red arrow under the bin and pull it out.
    • Remove the filter by turning it counterclockwise.
    • Prior to starting the repair, remove the battery.
  2. Dyson Cyclone V10 Absolute Motor Assembly Replacement: étape 2, image 1 de 3 Dyson Cyclone V10 Absolute Motor Assembly Replacement: étape 2, image 2 de 3 Dyson Cyclone V10 Absolute Motor Assembly Replacement: étape 2, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the one 16.5 mm screw on the back of the handle and two 16.5 mm screws under the battery.
    • Pull the battery downward to remove.
    • If you're just replacing the battery, follow the first two steps in reverse order.
  3. Dyson Cyclone V10 Absolute Motor Assembly Replacement: étape 3, image 1 de 2 Dyson Cyclone V10 Absolute Motor Assembly Replacement: étape 3, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the four 16.5 mm screws on the back of the vacuum.
  4. Dyson Cyclone V10 Absolute Motor Assembly Replacement: étape 4, image 1 de 2 Dyson Cyclone V10 Absolute Motor Assembly Replacement: étape 4, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the two 16.5 mm screws under the middle of the vacuum, in front of the handle.
  5. Dyson Cyclone V10 Absolute Motor Assembly Replacement: étape 5, image 1 de 2 Dyson Cyclone V10 Absolute Motor Assembly Replacement: étape 5, image 2 de 2
    • To separate the body of the vacuum from the motor assembly, gently pull them apart.
4 autres ont terminé cette réparation.
Kuiyao
Membre depuis le 09/19/22
267 Réputation
1 tutoriel rédigé
Équipe
York University, Team A-6, Morris Fall 2022 Membre de l'équipe York University, Team A-6, Morris Fall 2022
YORK-MORRIS-F22SAG6
3 membres
3 tutoriels rédigés
3 commentaires de tutoriel
Hi I didnt realize u cant vaccum up flour and i vaccumed up quite a bit that spilled. When i went to clean the unit the actual motorhead. After removing the sliding case i stood the motorhead ip and talled the end and all kinds of flour came out the end tube of the motorhead. I kept tapping and more and more flour came out. Is it possible to take apart motorhead or should i take it to repair shop. Please advise
Vicki Benn - Réponse
blow it out with an air compressor to get the flour all out...
Jeremy 888ferris - Réponse
Are you sure that the screws are Philips #1? They look like a torx?
Promachos23 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 104
30 derniers jours : 506
Total : 12,433
