Aller au contenu principal
Dyson DC14 Power Switch Replacement
Ce dont vous avez besoin
  1. Dyson DC14 Power Switch Replacement, Power Switch: étape 1, image 1 de 2 Dyson DC14 Power Switch Replacement, Power Switch: étape 1, image 2 de 2
    • Start with your Dyson DC14 unplugged, standing upright and facing towards you.
    • Remove the canister from the vacuum.
    • Disconnect the telescopic vacuum wand.
    • Remove the two T15 Torx screws securing the switch cover to the vacuum.
  2. Dyson DC14 Power Switch Replacement: étape 2, image 1 de 2 Dyson DC14 Power Switch Replacement: étape 2, image 2 de 2
    • Push outward on the two plastic clips that secure the switch cover to the vacuum.
    There are also two screws ( one of which can been seen on the photo and another a few inches below ) that need to be removed BEFORE pushing outward on the plastic tabs.
    martyn.lockhart - Réponse
  3. Dyson DC14 Power Switch Replacement: étape 3, image 1 de 1
    • Remove the switch cover from the vacuum.
    • The purple switch button may separate from the rest of the switch cover.
  4. Dyson DC14 Power Switch Replacement: étape 4, image 1 de 1
    • Holding them by their white plastic coverings, firmly pull the two wires from the power switch.
    • Be sure to grip the wires from their attached connectors. Pulling directly on the wires could damage your vacuum.
    • The terminals will only fit one way during reassembly. Only one of the wires is long enough to reach the far terminal of the switch.
    I can’t unplug the old starter. It seems stuck. What am I doing wrong?
    Jane Wells - Réponse
    I can’t unplug old starter from dyson dc14. Seems stuck. Help please
19 autres ont terminé cette réparation.
Zachary
Membre depuis le 10/06/12
315 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 3-22, Amido Fall 2012 Membre de l'équipe Cal Poly, Team 3-22, Amido Fall 2012
CPSU-AMIDO-F12S3G22
4 membres
8 tutoriels rédigés
10 commentaires
Thank you to the awesome student who made this tutorial! It worked perfectly and saved me the MAJOR expense of a professional repair. Great job!
Tim Swift - Réponse
The comment I listed below is not mine. I copied it from a Mr. Tim Swift who wrote it on 06/28/2015. Had I not have seen his comment, I would have said the exact same thing.
I have only one other thing to say......AWESOME!!
Bob Williams
robertvwilliams@comcast.net
"Thank you to the awesome student who made this tutorial! It worked perfectly and saved me the MAJOR expense of a professional repair. Great job!"
Robert Williams - Réponse
I replaced my power switch. Easy! $15 part!
brdurham - Réponse
Thanks from a 70 year old non-mechanical female with no torque wrench. I followed this tutorial a few months ago and found that my switch had simply come undone and I reinserted it but couldn't attach orange thing back cause switch kept slipping loose. I taped it up around switch so I wouldn't get electrocuted when turning on. Has worked fine til now, and I suppose my switch has finally failed, so I'm ordering new one. This Dyson was a refurbished one I got fairly cheap (for a Dyson) 12 years ago! SO, THANKS MUCH!!
Queenie - Réponse
Brilliant and saved me over £100 which is the cost of a Dyson engineer to attend plus switch. Name a charity.
Tariq Rafique - Réponse
This worked for me!!! Simply followed instructions and cleaned the switch by blowing air through it, re-installed it and hey presto!!!!
A massive
THANK YOU
ian - Réponse
Very thorough with great images and directions. I saved so much time and money using this tutorial. Thanks for sharing!
Theresa Wood - Réponse
Great accurate easy tutorial.
Kurt Ross - Réponse
Hello, I have replaced my switches and when I tried to put it back together, the brushbar reset arm fell out. I can't figure out how it goes back in! Please help!
Carrie Johnson - Réponse
Thank you! My vacuum wouldn’t turn off unless unplugged. $5 part and following this guide and it works again!
Fran - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 44
Total : 38,028
