Introduction
This guide shows how to remove the inlet hose of the Dyson DC39 Origin. This process requires removing the bin and separating the steering assembly from the main body of the device.
Ce dont vous avez besoin
Push down on the gray button located next to the power button to release the bin from the ball housing.
Pull the bin away, then up from the ball housing to remove it.
Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
Remove the four 18.0 mm Torx 15 screws.
Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
Push up on the steering assembly to remove it completely from the ball housing.
Remove the two 17.8 mm Phillips #2 screws located in the top of the inlet hose bracket.
Remove the two 13.7 mm Torx 8 screws located at the opposite end of the inlet hose.
5 autres ont terminé cette réparation.
