Aller au contenu principal
Dyson DC39 Origin Cyclone Filter Replacement
Ce dont vous avez besoin
  1. Dyson DC39 Origin Cyclone Filter Replacement, Bin: étape 1, image 1 de 3 Dyson DC39 Origin Cyclone Filter Replacement, Bin: étape 1, image 2 de 3 Dyson DC39 Origin Cyclone Filter Replacement, Bin: étape 1, image 3 de 3
    • Push down on the gray button located next to the power button to release the bin from the ball housing.
    • Pull the bin away, then up from the ball housing to remove it.
    • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
  2. Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: étape 2, image 1 de 3 Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: étape 2, image 2 de 3 Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: étape 2, image 3 de 3
    • Remove the purple pre-filter by pulling it up and out of the bin.
  3. Dyson DC39 Origin Cyclone Filter Replacement, Cyclone Filter: étape 3, image 1 de 2 Dyson DC39 Origin Cyclone Filter Replacement, Cyclone Filter: étape 3, image 2 de 2
    • Push down on the red button, located on top of the bin, to release the bottom section of the bin.
  4. Dyson DC39 Origin Cyclone Filter Replacement: étape 4, image 1 de 1
    • Push the grey button located in between the parts of the red lever to release the clear, bottom section of the bin.
    • The grey button can only be pressed after the bottom section is open.
  5. Dyson DC39 Origin Cyclone Filter Replacement: étape 5, image 1 de 3 Dyson DC39 Origin Cyclone Filter Replacement: étape 5, image 2 de 3 Dyson DC39 Origin Cyclone Filter Replacement: étape 5, image 3 de 3
    • You should notice several notches around the rim of the filter. Slide the plastic opening tool around the rim to release the notches.
    • After releasing all of the notches, pull the filter away from the orange cyclone assembly to remove it from the bin.
3 autres ont terminé cette réparation.
Sam Nelson
Membre depuis le 04/26/17
167 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S23-G6, Livingston Spring 2017 Membre de l'équipe Cal Poly, Team S23-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 8
30 derniers jours : 29
Total : 3,382
