Aller au contenu principal
Dyson DC58 Main Body Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Dyson DC58 Main Body Replacement, Bin: étape 1, image 1 de 1
    • Make sure your vacuum is unplugged.
    • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
  2. Dyson DC58 Main Body Replacement: étape 2, image 1 de 1
    • Locate the red lever parallel to the red trigger and on the side of the clear bin.
  3. Dyson DC58 Main Body Replacement: étape 3, image 1 de 1
    • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
  4. Dyson DC58 Main Body Replacement: étape 4, image 1 de 2 Dyson DC58 Main Body Replacement: étape 4, image 2 de 2
    • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
  5. Dyson DC58 Main Body Replacement, Main Body: étape 5, image 1 de 1
    • Flip the vacuum over so that the silver cyclone part of the vacuum is now at the base.
  6. Dyson DC58 Main Body Replacement: étape 6, image 1 de 2 Dyson DC58 Main Body Replacement: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Locate the two visible white clips seen between the main body and the purple cyclone of the vacuum.
    • Use tweezers to pinch the two visible white clips together.
    • It may require a few tries to pinch the clips since the space between the main body and cyclone is small.
  7. Dyson DC58 Main Body Replacement: étape 7, image 1 de 1
    • Tilt and pull the main body away from the purple cyclone of the vacuum.
    • You may hear a loud snap when the cyclone is released from the main body, this is to be expected.
12 autres ont terminé cette réparation.
Krista St Onge
Membre depuis le 09/17/15
2 188 Réputation
2 tutoriels rédigés
Équipe
CSU Fullerton, Team 2-4, Bruce Fall 2015 Membre de l'équipe CSU Fullerton, Team 2-4, Bruce Fall 2015
CSUF-BRUCE-F15S2G4
4 membres
19 tutoriels rédigés
4 commentaires
Mine ended up dismantled after it had been dropped. Couldn't get it back together until I read the bit about the tweezers /(pliers) and the white clips. It does not push in with out squeezing them first
Jason - Réponse
Has anyone replaced the red release catch?
chrisashton1 - Réponse
The white C-ring with clips must be pushed down in order to reassemble device. Takes some time to practice.
Anton Simonov - Réponse
I'm trying to figure out how to put spring and plastic pieces back in on the inside of red lever on motor body?? Any help I'd really appreciate ?
t_picano - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 46
Total : 13,083
