Aller au contenu principal
Dyson Supersonic HD01 Filter Mesh Replacement
Ce dont vous avez besoin
  1. Dyson Supersonic HD01 Filter Mesh Replacement, Unlock the filter cover: étape 1, image 1 de 2 Dyson Supersonic HD01 Filter Mesh Replacement, Unlock the filter cover: étape 1, image 2 de 2
    • Find the red dot along the top of the filter cover.
    • The red dot will be aligned with the white dot at the bottom of the hair dryer's handle.
    • Twist the filter cover counter-clockwise until the red dot is shifted to align with the white empty circle on the dryer handle.
  2. Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter cover: étape 2, image 1 de 2 Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter cover: étape 2, image 2 de 2
    • Remove the filter cover by sliding it off of the handle.
  3. Dyson Supersonic HD01 Filter Mesh Replacement, Remove the retaining screws: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    T6 Torx Screwdriver
    $9.99
    J'achète
    • Remove the two retaining screws at the base of the handle using a T6 Screwdriver.
  4. Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter: étape 4, image 1 de 3 Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter: étape 4, image 2 de 3 Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter: étape 4, image 3 de 3
    • Seperate the filter mesh at the plastic seam by pulling it apart.
    • Remove the filter mesh by sliding it off of the handle.
Ezra Linza
Membre depuis le 09/28/22
115 Réputation
1 tutoriel rédigé
Équipe
Utah Tech University, Team 1-5, McMurrin Fall 2022 Membre de l'équipe Utah Tech University, Team 1-5, McMurrin Fall 2022
UTAHTECH-MCMURRIN-F22S1G5
3 membres
3 tutoriels rédigés
4 commentaires
This guide is misleading and obviously trolling. The cable is attached to two ton of power converter bricks there's no way this thing will "slide off" the cable. lol.
gcb - Réponse
The REAL procedure is so complicated, the only REAL tutorial/guide i have found prefers to disassemble the entire device instead of dealing with the power bricks. https://www.youtube.com/watch?v=2XnUlUBZ...
gcb -
slide right off. lol. https://www.youtube.com/watch?v=fsiXJndd... hope you have a saw and several pry tools.
gcb -
updated the guide but i'm not sure how to add steps from another guide (on replacing the motor) up to step 6 only...
gcb - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 56
30 derniers jours : 232
Total : 3,224
